Old 04-29-2024, 02:38 PM
LAWN BOY's Avatar
LAWN BOY LAWN BOY is offline
Originally Posted by garydee View Post
Finally got around to adding starter relays to my 1641 twins. It was pretty easy. All wiring was done next to the solenoid with the relay mounted to the firewall. I bought 5 JD relays for cheap on epay...something like $10.65 with tax and free shipping from skyline-autoparts. Each relay came with a socket with wires for easy connection. The small picture of the starter shows a starter relay that was installed last year on the 1864 mower.
Also installed a bumper I purchased from ihccw.com on Dad's 1641 and added a spring to better hold side panels in place.
The last picture shows the 3 relays that were left over after the others were installed.
All in all, a fun day!
Nice. Interesting IH colored C decal on the front.
IH Cub Cadet 70 project, view my thread in the Kohler engines section for progress.
Old 04-29-2024, 10:43 PM
IHCub1450 IHCub1450 is offline
Finally got to mow with my 1450 Cub, but I got rained out.
1976 IH Cub Cadet 1450
2006 Cub Cadet GT-3200
Old 05-08-2024, 08:08 PM
Simple_man826 Simple_man826 is offline
ripped off read hitch plate pulling shrub stump. got 3 no problem but the last one must have really been in their
Old 05-09-2024, 03:25 PM
Farmall450's Avatar
Ripppp
I've been thinking about adding the frame mounted rear plate and hitch to my 1914 to keep the roller from pulling on the (AL) rear end.
Old 05-09-2024, 09:01 PM
im getting ready to make a much stronger hitch that mounds to the frame where the 3 point high bars go to avoid this happening again. im glad i found a nice used rear hitch plate for half the price of a new one. ill be sure to post the results of the mount i make. im going to use a truck hitch receiver and some 5/8 think flat bar. some hardware from a big box store and i should be set.
Old 05-10-2024, 02:32 PM
Opie55 Opie55 is offline
Default New Member. CC 3165
I’m a new member here. I’ve had a 3165 for a few months and had an oil leak from the transmission area. It leaked from the o-rings at the top of the auxiliary charge pump. After several attempts replacing the o-ring(s) it still leaked and got worse every time I messed with it.
I finally took the line off to get a better look and saw that the flange was cracked.
The line (727-3130) is N/A from Cub Cadet, so I silver soldered it and again replaced the o-ring.
It is holding for now so I put the front blade on and pushed some dirt around in the driveway
Old 06-09-2024, 09:09 PM
Put the 126 to work with the lawn sweeper. Just had to get the O out, as well.
Old 06-09-2024, 09:30 PM
Hairtrigger's Avatar
Hairtrigger Hairtrigger is offline
I had a Super Sunday
Old 06-16-2024, 06:24 PM
IHinIN IHinIN is offline
Sprayed the yard with 2,4-D to thin out the clover, ground ivy, and dandelions.
Old 06-16-2024, 06:49 PM
Got 3 Cubs cleaned up and loaded ready to head to RPRU tomorrow at Spencer, Iowa.
Taking the 126 w/hyd lift, 42" snow blade, creeper & 3 point, The 104 w/38" deck and 3 point and the 149/DanCo loader unit w/light materials bucket.
Plus parts to display including a new 383 Cat 0 lift kit.
Film at eleven.
