Old 07-06-2022, 02:14 PM
mortten mortten is offline
Did a little refresh on the 44C I converted to an A for the 1250. Wire brushed the underside, etched it and coated with POR15. Pulled the rebuildable spindles apart and cleaned them up and put new seals in. The old ones were bad and installed wrong. Wire brushed under the belt cover, etched it, primed and sprayed some white Rustoleum I had. Doesn’t match but it’s a worker. Sprayed some Fluid Film between the deck and support plate to keep the elements at bay. Greased the tensioner and the wheels and she’ll be good to go for quite a while.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 07-06-2022, 03:27 PM
I waved Bye Bye to the 108 as it went down the road w/a new owner!!
Old 07-27-2022, 09:18 PM
rsshallop rsshallop is offline
Spent the morning working on my Cub Cadet 1215. It's what I use to cut the lawn and the first cub I've owned. The wife bought it for me about 15 years ago. Before that, I used a push mower on our hilly 1/2 acre of lawn. Needless to say, it's been a big help. Regardless, it was dying when going up hill and by the way it was sounding, I figured it was struggling to get fuel. First I checked the fuel filter, but that was ok. Next, I focused on the fuel tank. It seemed a little grungy, so I pulled off the grommet with the fuel petcock and found the screen totally squished with a big glob of debris on it for good measure. I cut the screen right off as it was a mess anyway and squeezed the whole thing bank into the fuel tank without doing too much damage to the grommet. No leaks so far and the 1215 is back on lawn duty.
In the afternoon I turned my attention to my 108. I had the steering components all back in place and the next thing to tackle was the governor linkage. I replaced the well worn governor arm, spring and added the high speed stop that darkminion_17 pointed out was missing. I really didn't appreciate how bad those old parts were until I had the replacements in place. Anyway, the first time I tried to set the high speed adjustment, the engine started racing after a while. Fortunately, it turned out that I didn't have the governor arm fastened down tight enough on the governor shaft. Fixed that and re-focused on the amount of throttle cable at full throttle to have sticking through the clamp on the speed control bracket. Right now I'm at about 3500 RPM at full throttle, no surging and that's where I'm going to it at for the moment. Reason being is that now the starter generator belt keeps popping off. I'm taking the starter generator in to get rebuilt anyway as the brushes are pretty worn, so I'll have to figure that out later.
As for the steering, well the slope is gone and it steers far better, but it feels like the power steering that was on my fathers 1967 Galaxy. Something is obviously not tight enough, so another thing to take a second look at.
Still, a good day all in all.
Cub Cadet 108 / no mowing deck
42" snow blade
Old 07-27-2022, 10:18 PM
Nicely done. what you have described is several days ( or weeks) around
here, or so it seems. It's a great adventure and one it appears, you are enjoying.
Ken
Old 07-27-2022, 11:11 PM
Thanks Ken, OCC is great cause you learn stuff here.
42" snow blade
Old 07-28-2022, 10:33 PM
MitchJ MitchJ is offline
Put my new cast iron oil pan on my K16, and put it back in my 1650.
Old 07-29-2022, 12:15 PM
Inactive Member
What....???
Old 08-05-2022, 07:53 PM
Used my 108 to haul mud and weeds from the bottom of our property to the top of it. This was the first work that my 108 has done since I have owned it (and probably a few years before that).
42" snow blade
Old 08-07-2022, 11:32 AM
Cool picture. Any fish in that pond?
Ken
Old 08-07-2022, 12:56 PM
Kjamesm's Avatar
Kjamesm Kjamesm is offline
Made a little matching wagon to go with my Grandpa's tractor I restored. It was an old tire display trailer from my other Grandfather's gas station. Turned out kinda cool for kid rides
