Old 03-21-2016, 08:19 AM
twoton twoton is offline
Lookin' good Steve, glad to see your progress.
Old 03-21-2016, 10:14 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Originally Posted by Dirty Steve View Post
Thanks for the kind words. Took the leaking line off the hydraulic valve. Found NO o-ring. Matched one up to the line size, put it together and no leak after running for 35 minutes. Smoothed the carb out so it quit surging. Set the neutral on the hydro plate. Turned the front the axle bolt around- had the nut facing towards front of machine
Then I began stripping the Haban deck. I will strip it and ready it for paint. Only real problem is one third of baffle under neath is missing. Hoping get that welded up next weekend.
Steve, I had a 60" deck with the very same baffle that was missing as well. I used a piece of cardstock that I cut and formed into a template then used it to cut some steel into the same shape. The hard part was forming it into the curved shape, but then when I used one of the other baffles to form the new baffle, it was close enough where I could make simple as I was tacking it in before final welding.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 03-21-2016, 05:25 PM
Dirty Steve's Avatar
FrankF3 , thanks for the tips on how to shape the baffle. I have not thought that far yet....
Old 03-21-2016, 06:39 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Most any good sheet metal shop will have a roller that they can form the radius very easily with for you.
Looks great!
I just refurbished my Haban this winter... was a fun project!
Jay
Proud owner of the following:
Old 03-27-2016, 08:30 PM
Got some limited shop time in the last couple days. Happy Easter everyone! I had removed all the deck parts off my Haban 374 last weekend. Was able to strip some old paint and spread some new color. Must have about 8 hours into all that. These big old deck take alot of elbow grease. Feels like round twelve on this machine.
Old 03-27-2016, 08:33 PM
The deck itself will be a couple more rounds. Hope to knock it out in the next couple weeks.
Old 03-27-2016, 09:00 PM
jaynjeep's Avatar
Looking good!!
Jay
Old 06-23-2016, 04:07 PM
2182 has been on hold for a few months. Many irons in the fire. Plus it's been bleeding the whole time. I thought it was in major trouble with a cracked rear case or was leaking from between the rear case and adapter. I could tell the leak was low but could never figure it out. I ignored it for a while but recently got the nerve to investigate. I PM'd SamMac making a mountain out of a molehill hill as I went. Before I went throwing parts at it, Sam calmed me down and convinced to use Baby Powder. I powdered my rearend....... Instead of being an issue with the case, it appears to be the crappie galvanized 1/2 inch pipe plugged I used. I picked up a new steel plug. Hopefully this weekend I can get to stop hemorrhaging and continue bringing it back to life.
Old 06-23-2016, 06:34 PM
Looks good Steve, glad I was able to help. Sometimes chasing oil leaks can make you crazy. BTDT.
Looking forward to seeing you finish this one.
Old 06-24-2016, 05:53 AM
Speaking of bleeding to death. Time to make a decision.
