#101
Looking good bud!
That looked like the Maggy in my 1811. Them suckers run dirty but keep on chugging along.DSC01992.jpg
#102
Yeah, it cleaned up pretty good. Call my dealer tomorrow to place a parts order, then the fun begins...
![]() Good thing is the darn thing runs/ran so good, so theoretically it should run better clean.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#103
Doubt it runs better clean but I sure would bet it runs cooler!! ![]() Nice job with the clean up! ![]() The old Kohler "boxer" opposed twins never have really gotten the respect that they deserve... most of the failures were due to lack of service and or abuse.. I have several that have been really good engines... even got a KT 17 series I that has been running since 1980!
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
#104
Just picture a rod journal being splash lubricated by 30 weight oil, every other revolution, on any day much less cool weather. Add to that some engines had sat unused a long period of time between uses, and remember when the engine is hot @ shut off the oil is water thin and drips away easily. As we know the later series 2,and magnums cross drilled the crank for pressure lube to the rod journals and gave them a pressure regulator with at least #50+ cold. So yes, the old double breasted flathead kohler is a song to appeciate, @idle or WFO with little shake rattle or roll.
#105
Your power washer did a good job. Engine looks a lot better.
Stanton 1980 IH 782, Kohler M18 IH #1 Cart, original IH 42" Blade, modified to 50" and hydraulic 2015 XT2, Kawasaki 23 HP |
#106
It always amazes me that an engine can just keep on keeping on when it is so full of dirt. I just took the engine loose in my 2084 and although thought I kept it pretty clean it also was a mess. You did a great job on yours. Maybe we should call you Mr. Clean.
#107
Get in contact with Dirty Steve, he just picked up a muffler with a bunch of other stuff. I'm sure he will cut you a Lew deal on it.
#108
#109
Back into the 1811 after a week of slacking.
![]() Got all the gaskets, and seal, so it "should" be the end of the oil leaks. I HOPE anyway. Check out the backside of the flywheel after I got in there with a screwdriver and loosened all the grass and s#$t... ![]() Need to fab up some remote oil filter lines yet. Going into town tomorrow and see if Napa can help out in that department. There isn't anything salvageable on the old ones.
#110
I hope you used some of that 5 dalla paint.
