Old 07-02-2023, 01:53 PM
Jb4249 Jb4249 is offline
Default 1250
Pulled this from behind a friends shed. It had been sitting several years. Rebuilt the carburetor new plug and blew out a couple pounds of mouse houses and it starts and drives. I had to rig a fuel tank, I was able to buy a used one from this site I tried to up load a video of it running but couldn’t
File Type: jpg DFE997F6-6282-4140-BF7C-25E32CF2172A.jpg (46.7 KB, 265 views)
File Type: jpg FEDA5232-C972-4CD8-B38B-780EAFE1F4DD.jpg (38.9 KB, 267 views)
Old 07-04-2023, 02:03 PM
Farmall450's Avatar
edit: wrong forum, gets me every time.
Old 07-04-2023, 07:39 PM
IHinIN IHinIN is offline
Yesterday, I hauled 1,400 lbs of patio pavers with the 129 and homemade 1-ton cart from the barn to the path I’m building from the house to the barn. The tires didn’t pop, so it passed the stress test.
Old 08-20-2023, 06:39 AM
Radioguy41's Avatar
Radioguy41 Radioguy41 is offline
I used the Agri-Fab rake to rake the stone driveway after a recent storm washed huge gullies in it. Also did the bottom of the neighbor's driveway and the street in front of both. This might be the best implement purchase I've ever made. Love this thing!
Here's a pic from earlier this year.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
1993 Craftsman LT4000
Old 09-16-2023, 05:23 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Went to Allen and Jenn's house and worked on his "O".
Come home and planned an engine swap between a 122 and 123
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 09-18-2023, 07:27 PM
LAWN BOY's Avatar
LAWN BOY LAWN BOY is offline
Default Pulled engine for rebuild!
Tonight, I checked the valve tappet clearance on my IH Cub Cadet’s Kohler K161 7hp engine and found it to be in the close enough range and don’t think that is why it makes flames in the muffler. The motor also runs pretty high and won’t idle. So I removed the engine so that I can rebuild it this Winter. This will be my first time rebuilding a motor. I plan on using the ultimate rebuild kit from isavetractors.com.
https://www.onlycubcadets.net/forum/...pictureid=8366
https://www.onlycubcadets.net/forum/...pictureid=8367
IH Cub Cadet 70 project, view my thread in the Kohler engines section for progress.
Old 09-19-2023, 09:34 AM
walkertxr walkertxr is offline
Default 122 headlights
Figured it was past time to get the wiring done for my 122 lights since it came on the tractor but just never got around to hooking it back up after a refresh a couple years ago. Well first headlight came on and looks great. Second one came on, smoked then went out. Darn 60 year old bulbs anyway. Robbed parts out of license plate light to fix the taillight, the bottom of the light socket was missing.
Old 09-20-2023, 09:21 AM
jbrewer's Avatar
There's some great LED replacement headlights (PAR 36?) that work great.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 10-23-2023, 08:09 PM
Richard Streib Richard Streib is offline
I cleared the clogged gas line on my 122. Put on a new shift knob, removed the wheels and took them to the tire dealer for new ag tires on rear and 3 rib tires on the front. Replaced the torn seat with a new one.
Old 10-23-2023, 08:10 PM
Default Battery cut-off
Do you use a battery cut-off switch on your vintage Cub Cadet? If so, what kind do you use?
