#1141
I rolled my lawn but also finished my addition of a hitch to the tree spade
#1142
Here is the scoop attachment i'd like to get running. Its missing the arm to raise and lower the lift and the hoses to operate the tile but overall seems promising for a custom fab. the previous owner spent some time putting this together but the owner before me said he never used this attachment.
The arm for the snow plow is a bit shorter than what this would need to work, I suppose I could bring the required dimensions to a machine shoe to make this piece and cobble the hoses together with some stuff from tsc. Id be happy to hear your takes or cautions on trying this thing out. |
#1143
Well the last few days has been challenging with the 1650 that some of you guys may recall from years back. The k341 in it has been hard to start ever since I bought it 10 or 12 years ago. Recently it's been smoking badly, reminded me of the skeeter sprayers of old. I've had the donor engine for a while and finally time to swap. It came from an Aries tractor with a bad trans.
The caveat is this engine has the deep fall bottom pan that bolts to the frame and isn't a direct swap into these tractors. I had planned to mount on some 1/4"x2" bar stock. That changed after some thought. I have a roper parts machine that I got for the engine. I remembered that v-twin was bolted to a flat plate. I scavenged the plate trimmed for length as width was nearly perfect. I first tried bolting the new engine in but the bolts didn't give clearance to the oil pan so I welded it in, really didn't want to alas we do what we have to do. So now the plate is in and a trip to the store for longer bolts the motor is in its new home. All's that left is mount the accessories and go through the carb, maybe.. Next project with this machine is try to make the cat-0 I had on the 1782 that burned up to work on the 1650. I know it's not a direct fit but with some creative fab work and a few project tractors I think I can make it a reality..wish me luck.. I'm attaching a video of the old engine for you guys, I can't promise it has no colorful language though I don't recall in my narration.. https://photos.app.goo.gl/xMTexmbFU4CS1hacA
126 in surgery with weights, spring assist, 3 point and sleeve hitch 100 with woods finish mower and rear lift, Nice 125 with super nice sweepster, 1782 Super Diesel, 1650,782D in surgery, 102 parts tractor.. 3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
#1144
This 10 month 782 restoration project comes to a close. Operating a just restored Cub where everything is working as it should and no fluids leaking is quite a thrill. She's ready now for another 44 years of service.
INTERNATIONAL HARVESTER - We build the machines that work. 1811/682/782/1440/IH #4/IH QA 42" |
#1145
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
#1146
It will be a worker, they all have to earn their keep around here. After six complete Cub restorations, this 782 is the last one for me. Finding NOS parts, even some salvage and Kohler parts has become way too difficult bringing them back to stock. I don't mind the restoration work, just enjoy using them more.
#1147
Wish my 782 looked that good.
2005 CC GT2544 1980 IH CC 782 1957 Cub Lo-Boy 1993 Craftsman LT4000 |
#1148
A few weeks ago, my 126 stopped moving while I was cutting grass with it. I finally got time to look at it this weekend. I checked the pins in the driveshaft first, and they were all good. I noticed the shift lever for the creeper gear had no resistance, so I assumed the problem was in there. When I pulled the drain plug out, the pin from the fork fell out. The hole is worn out of round, I drilled it out and put the next size bigger pin in there. It seemed to fit tight, hopefully it stays this time. I put it back together and cut grass. Everything was going good until the mule drive belt shredded. I didn’t have a spare, so I finished with the 1440.
#1149
Can yall help?
#1150
Good news/Bad news
Good news, it appears to be in very good condition. Bad news, it ain't made for your 682. |
