#111
No idea what I needed, wanted, had to have one of these for. Oh wait.... I remember now. I didn't have one ![]() Did figure it would work good with a sweeper being it turns sharp
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#112
I did think of a PTO device that would be perfect for a trike and you'd probably have the only one on the planet... of course you'd have to build it...
Belly-mount string trimmer. As sharp as that will turn it would be SWEET for fences and you'd never have to pull start a weeder again! Might have to go with something more durable than a string though since you couldn't "bop" the head.
#113
#114
Too bad it isn't a gear drive. Then you coulda put a rear PTO on it and made a rear sickle bar mower!
What other uses could we find......
#115
A belly mounted grader blade would be cool if you have a gravel drive.
I like to keep em running and work them. 1872 (I call her Vera), 782D, 154 Loboy (w/tiller, 3260 deck, and front blade), 3-1650s, 2-1000s, 149, 147, 106, 1810, Farmall Cub, Haban sickle bar (not mounted), No. 2 trailer and several parts tractors. |
#116
I have this desperate need to make the PTO functional (in my own mind... with someone elses tractor)... It just seems like pulling something isn't enough.
It's pretty non-agricultural, but it would be pretty slick to make a mobile repair attachment for it. Generator on one side and air compressor on the other. Even better a gen-set welder would be a step into legendary. You have the real estate now to keep it within the rear wheel width... Drive up, clamp on, and away you go.
#117
The string trim mowers don't use "bop" heads they just use a fixed length heavy string that snaps or threads into the head. My Husqvarna string mower has a system where you fold the sting in half and push it through a slot and hook it over a tab, pull until it bottoms out and you're done. I cut what I think I need for the job, in pairs, from a roll and stick them in my pocket (securely, so as not to drop them all over the place... don't ask why I say that) and put them on the head once I've hit the fence wire or posts enough times. Can change them both in about 30 seconds.
Cub Cadet 86 Mahindra eMax 22 w/FEL Husqvarna LGT2554 John Deere GT275 '48 Ford 8N '41 Ford 9N Yerf Dog Scout CUV |
#118
I'm thinking it's done enough for a couple pictures. Was a fun little project, fought me all the way. But I showed that sucker
![]() Looking forward to a ride tomorrow. Unfortunately it's got a little drip out the back end. I thought I got them all, but missed something, someplace. ![]() Don't know if the pipe is staying on yet or not.
#119
Excellent job, Todd!
#120
Pop any wheelies yet?
How well does it steer?
