#111
I decided to put the bearing plate on before painting the block. I measured the crank end play at .010. I'm going to put the piston/rod in sometime this week and then wait for nicer weather so I can paint the block.
#112
Don't forget the end play on the camshaft.
Too loose and it will give you the "Kohler Knock Syndrome" |
#113
that's usually the cam that knocks.
#114
does anybody have a place to get shims that isnt 5 bucks each?
#115
Cam shims?( balance gear shims will work i think) Bearing plate? I think i have a few extra. Since you will be powder coating now, how about ceramic coating. Can you do that? I have a set of headers i need done. Mike
#116
Yes I was referring to cam shims, when I looked them up on parts tree there $5.50 each which seems pricey for what it is.
#117
Cam end play should be .005-.010. I'd try for 1/2 way between.
and the cam pin only goes in one way, the same way it came out, Important! You are doing a major overhaul on an engine! And you are worried about spending another $5?? |
#118
I was just wondering if anybody found a less expensive replacement so I could order several and have them on hand for future builds.
#119
McMaster Carr has 10 packs for less than $5 a pack.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
#120
Do you happen to have a part number?
