#111
A flange mount has the bolts in the same plane as the shaft.
#112
Like this.
#113
Due to geometry of my engine/rear axle, my lower pulley is directly over the hydro's filter, so my pulley is limited to 3.5 inch dia. With your larger pulleys and a fatter belt, you may be fine. My belt shredded (I think) when the hydro seized momentarily.
Well that is one impressive build! You can always tell when you've done a great job when people comment, " I didn't know they made such a thing" meaning it looks factory built and not home made. Not much you can't tackle after this project!
I'm guessing you have the donor hydro in place, since it's all buttoned up? |
#118
Totally Awesome!
Alan Basket Cases: 129, 1450 sold, 1650 125: 48" Mower Deck, Windbreaker Cab 127: 3 turn steering gear, Spring Assist, Sleeve Hitch, 48" Mower Deck, Dozer Blade 147: 3 turn steering gear, Spring Assist, QA36a w/Xtreme Motorworks Wings |
#119
Excellent video Frank. The build is superb! Excellent all the way through!
#120
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
