Old 05-27-2023, 07:44 PM
We use a bunch of this insulation in HVAC. The brand most widely used is Armaflex in our trade but Armacell is probably just as well made. It will hold up well for many years. I replace all of mine when the hoses are removed also.
Old 06-04-2023, 07:57 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Originally Posted by 1711Cub View Post
Due to an intermittent no crank situation, I decided to replaced the tired starter/glow plug dash key switch using a new OEM Kubota switch. All of the exterior terminals were dirty, and if I were to dissect the original switch, the contacts inside the switch are assuredly suspect. The biggest issue with these was that in it's original configuration, a great deal of current went through the contacts in the switch to power the glow plugs. With the modified system with a glow plug relay, that will reduce the load through the switch, so in theory, should last a very, very long time. That key switch is physically large and heavy! The few times I tried the starter after the install, it cranked every time, so it appears that it fixed that issue.
This is interesting. Mine make a ticking sound (I think it starts the fuel pump) but might take 2/3 tries to finally fire the solenoid to start cranking. Is that what you were addressing?
Sounds like you replaced the existing switch and added a relay to handle the current of the glow plug? Was this something Kuboda / IH did a long the way, or something you came up with?
Thanks
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 06-04-2023, 10:40 AM
That’s the GP upgrade John. I think it’s listed in the tech section here.
Old 06-04-2023, 02:45 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Thumbs up
Thanks
John
Yes, I had to hit the key a few times before the starter would engage. After the new switch was installed, it worked the first time, every time.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 06-04-2023, 02:54 PM
jbrewer's Avatar
Thank you gentlemen. That is excellent news and I'm off to search for the mod.
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
