Old 05-30-2010, 10:02 PM
murphycc
Guest
Posts: n/a
You would need to remove shims to reduce the pressure. I think my manual says that 782s are set at 600-700 psi, and the larger 982 at 7-800 psi. I wouldn't go a lot higher than 800, either.
The 982 pump had a relief valve set at what you posted. The pressures were increased on the later Cubs, 900+ IIRC as the 982 struggled to lift the tillers. This is one reason I went to the 1882 pump on my 982.
BTW...no sweat on the lift low, big difference.
Scott
Old 05-30-2010, 10:07 PM
murphycc
Guest
Posts: n/a
IHinIN,
I suggest a remote relief valve, the one I bought was about $40 and it's adjustable from 500 to 1500 psi and very quiet and smooth.
Scott
Old 05-31-2010, 09:48 AM
IHinIN IHinIN is offline
Here's an exploded view of the relief valve in a GM pump. The shims go between the end cap and piston housing to decrease pressure on the spring. To increase pressure you remove shims and/or add small washers under the spring.
Old 05-31-2010, 09:57 AM
Yep, that's definitely different.
What brand pump do you have?
Old 05-31-2010, 10:02 AM
I assume it's a Saginaw pump. It came off an early '70s Chevelle I believe.
Old 05-31-2010, 01:39 PM
Amigatec's Avatar
Amigatec Amigatec is offline
Those GM steering pumps are almost the same from 1962 to at least 1985 or so. The only real diffenrence would be the thread and the can on the back. The same rebuilt kit should fit all of them.
Pat Benner Haskell OK
Old 05-31-2010, 03:58 PM
Great job, Bill! You have been busy.
Old 05-31-2010, 09:26 PM
Lmiller Lmiller is offline
Default she got the day off!!!
I worked her yesterday plowed up a small garden, disked it up, then dragged spring tooth?/ chisel over it for kicks! ol cubs tired... need to build a power lift for it... the manual lifting wears me out!!!!
Larry
Old 06-01-2010, 03:30 PM
JayBrd's Avatar
JayBrd JayBrd is offline
Busted out the "O" this weekend to finish up moving the last of the dirt pile. Both of them got a good work out doing the last of the heavy work for the new landscaping..
Jay N.
Eau Claire, WI
RED 82 Series...
Old 06-01-2010, 03:54 PM
TheSaturnV's Avatar
Terrific shots and great looking pair of machines. Any more pics of the landscaping, etc?
