Old 01-08-2016, 10:10 AM
That's a nice looking setup, do you happen to have some part numbers for the rams?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-08-2016, 10:12 AM
Nightow1 Nightow1 is offline
Well it works much better, it gives more lift around 14.5" , as far as weight and mind you we probably will never test it to it's max so far around 600# but without a doubt could lift 1K. Need some more weight up front first. The single cylinder mounted on the back that we started with had to much of a mechanical disadvantage and was no better than the IH original design. Remember when we started this build its intention was to be bigger, better and a one of a kind BEAST! We wanted a GT that could be used with any implement that we could come up with, but still a good mower and easy to operate.
Old 01-08-2016, 10:13 AM
The cylinders we got from Surplus center. If I remember correctly they were 2" with a 4" shaft.
Old 01-08-2016, 10:51 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Here is the link to the exact cylinders we used.
http://www.surpluscenter.com/Hydraul...E-9-7710-4.axd
1- 1200 in pieces
1- 1864 in pieces
Old 01-09-2016, 10:08 AM
V30crewcab V30crewcab is offline
Nice, thanks for the parts link. anyone have measurements of how far the end of the links are off the ground at full drop?
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 01-09-2016, 12:30 PM
1811woody's Avatar
Awesome build guys You both did a great job. From the looks and sounds of it Rescue11 has a good amount of experience with hydraulics, that's an amazing job on the tubing. I'm curious on how much room you have under the sheet metal for the tubing after everything is back together did you have to change your wire harness or alter your sheet metal to make room for all the extra tubing and valves ?
Old 01-09-2016, 12:33 PM
Just a few extra wires to account for the 12V selector valve other than that nothing was done to the sheet metal at all.
And thanks, it was a nerve racking build. But worth it. Still a few more things, she os getting a canopy and lights.
Old 01-10-2016, 12:03 AM
Rescue11's Avatar
Thank you, there is plenty of room, considering there is around 90 feet of steel line in that thing. Thats a major plus using steel line, 4. 3/8 steel lines fit where 3 1/4" hoses will not. Better flow, aesthetics, etc... very time consuming.
Depends on your lift link adjustment, currently they are 1" from the bottom of the end, but the center lift links are different from the original.
1- 1200 in pieces
1- 1864 in pieces
Old 12-06-2016, 10:27 PM
well its been awhile since we have posted any updates so here it is.
we finished the hydraulics, front blade, R-Bucket, Hydraulic top link, and 3pt.
most of it was just finishing touches. we decided on Sunday that we wanted a Hydraulic top link so the R-Bucket could dump in the #2cart.
here are a few pix and links to videos of the 782 BEAST and its winter Attachments.
Just a side note Remember when were asked "Why would need so many hydraulic ports" Well this is why, and its not over. We are installing 2 more 12V hydraulic flow valves so we can add a custom V-Plow. then we will be able to control the front and rear implements independently from a simple foot switch. cant wait to start that.
https://www.youtube.com/watch?v=t3pQbmRKGO8
I Have a walk around of everything working will upload when it finishes. youtube is slow on my phone
Old 12-06-2016, 11:16 PM
That right there is just too cool. Great job gentlemen.
