Old 04-09-2017, 08:39 AM
john hall's Avatar
So, you gonna get a good used rockshaft assembly? Might be better than salvaging what you have there. Certainly a lot of work to drive that pin out--thinking if you had a good used setup, you could cut the old one into a couple pcs with a sawzall. Here is how I did it, used something big to brace the frame--go to pic of the tractor with he scrape blade.
http://www.onlycubcadets.net/forum/s...t=46542&page=5
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 04-09-2017, 01:25 PM
Okay, I'll see your 2 cents, and ... You don't like the hose, or clamps, or you thinking it'll leak? Nothing is set in stone, there is time to use an alternate route.
Just figured it's low pressure, and there wouldn't be an issue. I had a hose made at Napa today for the 782, but they used hydraulic hose, and it's stiffer than a teenage boy in the girls locker room.
Plus on the 782, the hard lines had the threaded connections still intact, but this one was already "worked on" if you smell what I'm stepping in?
Dr. Todd
This is the stuff I would use if it was my tractor.
These are the fittings, scroll down till you get to the socketless fittings
http://www.speedwaymotors.com/shop/o...2-25-286-18126
This is the hose. My guess is you probably need dash 6 size but without know the size of your existing fittings I can't be sure
http://www.speedwaymotors.com/shop/a...2-25-327-18140
Call me if your have questions.
Old 04-09-2017, 11:32 PM
Not sue yet John. I may have "forgot" one pin, will take a look see tomorrow.
Dr. Todd
Okay, thanks for the info Sam.
But back to my question. "Why, you don't like the hose, or clamps, or you thinking it'll leak." Just trying to save a few bucks, but still have it work as should.
Old 04-10-2017, 07:33 AM
Todd I'm concerned that using fuel hose for hot engine oil may lead to a hose failure. The stuff I listed is rated for 300 degree oil and 250 psi. You may be able to push the hose over the existing metal lines that come from the engine and clamp the hose. What is the OD of the metal lines?
Old 04-10-2017, 07:10 PM
In the house now, I'll check tomorrow. All I know is I told the Napa dude what I was using it for, and this is what he gave me. Don't mean it's right though.
Well I got the rockshaft out today. No, I didn't forget a pin, or bolt, it was just seized. After soaking since yesterday in PB, some BFH action, and patients if finally gave up.
Cut out the shot pins, made a couple new ones out of bolts, cut to length, just have to drill the holes and weld them in. Good to go!
free upload image
free photo hosting
image hosting no register
Old 04-12-2017, 09:09 PM
Sam, hard lines are 1/4".
Here's yesterdays progress. Rockshaft fixed and installed.
Old 04-12-2017, 09:21 PM
The OD on those lines is only 1/4"?
Old 04-12-2017, 09:31 PM
Good job, Todd!
Old 04-12-2017, 09:50 PM
Dirty Steve's Avatar
Great work, Sir!
Old 04-12-2017, 10:15 PM
DieselDoctor's Avatar
Pretty sure the oil lines are 5/16 Sam. The newer ones that two piece are AN-5 fittings.
