#131
Ordered a few new parts/bolts to get the 104 back in tip top shape before I decide if it will be my first restore tractor or worker.
Cub Cadet 104, 107 |
#132
Brought the 982 into the shop for spring servicing. Changed oil, sharpened blades, greased, changed hydro filter, gauged tires, washed off---2 months late, but better than never.
#133
Cut the grass with the 2372.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#134
Todd, What time do we tee off? Your yard is gorgeous!
Queen Of The Quietlines!
#135
Great looking property you have Mr. Todd.
Glad the 2372 is up to the challenge!![]()
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights . {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
#136
I'll leave that up to you Beth. Plenty of obstacles.
Thanks.Quote:
#137
Installs a few new clevis pins and bolts(appropriate size, fixing tacky repairs). Removed the deck to start a complete rebuild/repaint. Removed the mule drive because it's all bent up, so I'm in the market for another one. Got the clutch return spring installed and started reading about adjusting the clutch so that may be on the menu for tomorrow.
Noticed some oil seepage from around the head gasket, going to dive into that further. Got a compression tester to check the motor may do a top end rebuild while I'm in there. Also noticed a miss at idle, so I'm going to dig into the carb a little bit. ![]()
#138
Compression tester won't work on these engines, they have a built in compression release to help them start so the tester will read really low. Unless you're going to bore the engine I wouldn't mess with it, putting new round rings in an egg shaped hole will probably smoke worse than it does now. Pull the head and resurface it and install a new gasket, I always pull the valves and clean them while I have the head off just to avoid them sticking later. Here's a link on how to resurface the head yourself.
http://www.onlycubcadets.net/forum/s...ad.php?t=45286
#139
#140
Those engine will still run great even when they smoke like a freight train, a little on start up is pretty normal.
