Old 07-17-2010, 10:57 PM
Nice work, Bill & Diz!
Old 07-17-2010, 10:59 PM
Sounds like you had a busy maintenance day also Wild Bill.
ACecil
Old 07-18-2010, 01:54 AM
A few years ago I bought several Cubs from a fellow on the Eastern end of Kentucky, one of which was a pretty nice looking 70. When I got them home I started them all just to see what I really had.
This 70 seemed to run pretty good, so I mowed one round in my Brothers yard with it. The engine had a noise that I quickly determined to be the flywheel screen, and the head gasket was leaking (not bad but it was leaking), it also steered pretty hard. I took note of these things and parked it in the back of the shed to mess with another day.
Another day finally came, so I pulled it out of the shed, brought it home and went to work. I pulled the carb. off, took it apart and put it in the carb. cleaner to soak. I pulled the engine out, took off the shroud and flywheel cup and screen. I put new bolts in to hold the screen (all 4, three were missing and one was too short). I took the head off, decarboned the top of the engine, sanded the head flat and put the engine back together. Then pulled the steering column and rebuilt it, put it back in. While the engine was out I replaced the clutch fork bracket. Then put the engine back in and hooked up everything except the carb. The next day I blew out the carb. body cleaned and blew everything out and put it back together with a new kit. Put the carb. back on, greased all the zirks, fired it up and set the timing.
What a sweet running tractor, I really had fun cutting grass with it.
It still needs some clutch/drive shaft work, the only thing that looks wrong is, the teaser spring is broken. Hard to tell if it will need any real work until it's apart, it seems to work well, just a little jerky on take off. Being that this isn't my main grass cutter or anything (just something to play around on) I may not put a lot of work into the clutch/drive shaft, depends on how bad it looks when I get it apart.
All in all I'm pretty happy with it, it makes a nice little trimming machine. The cast iron end deck really cuts well too, I was a little surprised.
Old 07-18-2010, 08:51 AM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
Finally got caught up with most of the breakdowns we had lately and now my garage is missing a 102,149,108 and all I have left to work on is the 800. Finally got the rockshaft pin out and replaced in Dustin's 149 so it's back in mowing duty. Funny thing is I have been repairing all these Cubs...except my own. Seems funny to see only 3 tractors in the garage and to have gained more room...
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 07-18-2010, 06:54 PM
camarokidz28's Avatar
Default Elenor update
Was a slow 3 days of sanding these parts down to metal , fenders , hood and some seat parts . Looks like it was painted 3 times before i got it .
When i get to the cast parts i will get out the sand blaster
Denny
Original Member # 389
Saw It
Wanted It
Had A Fit
Got It
Old 07-18-2010, 08:20 PM
Looks good camarokidz28
Old 07-19-2010, 10:03 PM
Got these done today . Thuresday will the pull motor out and clean it up
Denny
Saw It
Wanted It
Had A Fit
Got It
Old 07-19-2010, 10:31 PM
camarokidz28
Old 07-19-2010, 10:32 PM
Nice work, Denny!
Old 07-20-2010, 11:05 PM
johncub7172's Avatar
Nice job on the 169 mowerdeck! That thing looks like it can fly!
