#141
My serial is 821130 so later right?
#142
You're in the last group of 2182 serial numbers
Cub Cadet 2182 S/N 800,000 - 816,535 Cub Cadet 2182 S/N 816,536 - 821,059 Cub Cadet 2182 S/N 821,060 - 880,000
#143
Well that seller got horrible reviews i'm back on the hunt
#144
#146
Numbers work so it should play.
#147
Well frustrating day today, filled transmission with roughly 7 quarts. And got my wires all hooked up and such. New plugs, wires, coil, rotor. So it was really hard starting and smoked profusely while trying to start but once running it would smoke much less. It would run 30 seconds and die. It started twice. I cant figure out if its timing, valve adjustment, maybe its a blown head-gasket (the cap to the puke tank is missing which is suspicious) the carb could be dirty and not feeding enough to sustain fuel delivery? (The fuel hoses are very rotted) lastly i checked the trans fluid and it was completely dry. The trans has sat with the cover off for weeks, could it need more than 7 quarts?
#148
I don't care if it's a Kubota or a Kohler, a decent fuel system is critical or it won't run. If you haven't yet pulled the tank, replaced every hose from the tank, cleaned the fuel shut off valves, replaced the filter and cleaned the carb. Your kidding your self expecting it to run well. Ask me how I know. Fuel, compression, spark or we no gonna go varoom.
#149
I needed someone removed to give me some direction. Thats gonna be might next repair. |
#150
Take some time and read through this thread about the 2182 I'm in the middle of now. The fuel system was a total mess. You can see what I did just to get it running so that I could decide if it was worth saving.
http://www.onlycubcadets.net/forum/s...ad.php?t=35311
