#151
The O has always seeped gas out around the sediment bowl to tank junction...like for 10 years it appears.
I took the tank out, stripped it down primed and painted it . Of course, installing the mounting bands scratched it up some but it's better than before, that's for sure. And.... IT DOESN'T LEAK! I'm now a BIG fan of Permatex 2 that I used sparingly to seal the threads. Now, to enjoy it before on to the next repair (likely either the steering column OR the front axle pivot bolt wallowed out hole) Another small victory... John
#152
Great news, John!
#153
Awesome news!
#154
Well, it's not very spectacular but it's nice knowing that I'm less likely to turn into the human torch as gas drips on the coil.
Permatex 2. I don't know why I didn't think of it earlier. Doesn't harden, gasoline proof and good for sealing small gaps. Doh! John (heading out to Sanford )
#155
What IS the recommended fix for a wallowed out (technical term) front axle pivot hole? Is there a suitable bushing that can be used for this?
Any other pitfalls in what looks like a relatively simple (bwhahahah) fix? John
#156
JBrewer: Great thread, I've just read it from start to finish.
I don't know if it is possible to do on an "O" --but if you can install a bolt, even cutting the head a bit thinner, then you can re-size both the "pin" (thicker bolt) and hole (in cross-member) it is possible to remove ALL the slop. I even went to a metric bolt in my 782, but it came with a bolt originally. The advantage to a bolt, of course, is that you can tighten it up to properly "clamp" the axle. Jeremiah |
#157
The last post on this thread is 10/12...inquiring minds want to know what is next and how did it work out?
I appreciate the time and detail that you have put into this thread, that is for sure! Tony |
#158
I've not abandoned this thread or the O...as a matter of fact I used him this past weekend to do sweeper duty as I do most every weekend.
There's been two slowdowns....one, I started a new job, which has taken ALL of my time this year, and two, I spent two weekends I SHOULD have been using to fix the front end , with trying to get the #)$**#$ing steering wheel off of this thing. I've heated, hammered, pulled and Pblasted this thing and I STILL can't get the wheel to budge. Rather than break it, I've just been USING this Cub. It remains one of the most reliable tools I have in the IH toolshed. I DO need to attack the front end, as it's REALLY in sad shape. Thanks for the kind words on the thread. I've learned a LOT from people sharing their work and it's my hope someone could pick up one or two items from my misadventures. John (and "Scrappy" the O)
#159
John, want to me to bring my cub and sweeper up, and help you out one weekend?
#160
