Old 03-17-2016, 06:36 PM
JLM78 JLM78 is offline
This stuff about the drive shaft length is from an old post but I'll cover it again.
That is not an 1864 or 1863 shaft. Here is the info for the shaft you need.
Shaft, Drive, 20.38" Lg Part Number: 738-3098 ( 1863 &1864)
Jason drill and tap the pump shaft for a 1/4"-28 X 3/4" I use a right angle drill when I do them in the tractor. Just drill it till you get to the hole that the old spirol pin went in. Take your time because the shaft is hard and what ever you do, do not bust the tap.
This What I have coming out of a 1863 cub
Old 03-17-2016, 06:42 PM
V30crewcab V30crewcab is offline
a masonry bit has a carbide tip and will get you through the hardened part, then you can drill it like normal. I just had to drill a 9/16 hole into a trans output shaft I'm adapting a different transfer case to.
I think the 1862 runs an 18" shaft. that might be what yours is from.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 03-18-2016, 10:53 AM
MWShaw's Avatar
MWShaw MWShaw is offline
Originally Posted by JLM78 View Post
What size Did you drill and tap the pump shift ?
I used a #7 drill and a regular tap. No hardened tooling. The shaft seems to be case hardened, not fully hardened.
Go slow, use some clean oil to lube the drill and tap. Use compressed air to clear the chips out of the hole, prior to tapping it.
Use a new tap, you should be fine.
Drilling and tapping is part of my day job, I've done quite a bit of it over the past 31 years, so I may over simplify it.
Old 03-22-2016, 04:47 PM
One 1572 down One 1572 to go. Put the drive shaft and Braces on
Old 03-22-2016, 05:54 PM
Looks good Jason. How do you like the CV drive shaft?
Old 03-22-2016, 08:32 PM
lot less Vibration. The old Drive shaft was worn at the engine end. The piece the hooks the drive shaft to the engine was worn bad. Thank you for everyone's help
Old 03-23-2016, 06:14 AM
MWShaw's Avatar
Looking good!
My braces have shipped, those should go on next week.
Old 03-23-2016, 11:41 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Nice job Mike!
I wish I had enough time to do the same. I have the braces sitting all painted in the garage waiting to go on. After I finish the engine rebuild I am on for the chipper/vac, those are next up on my list, both for the 1572 and the 1772. At least the 1572 has the driveshaft in it already.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 03-23-2016, 12:46 PM
Looking good!
Thanks. The braces are easy to put on. Only thing The rear end Gear Oil run out of the holes
