Old 05-17-2018, 07:58 PM
ironman's Avatar
ironman ironman is offline
Originally Posted by Chad126 View Post
LOOKS FANTASTIC! Great job!
Now time for beer. Beer is for when the job is done, and it looks to me like the job is done. Grass cutting can wait.
Times two on the great job, but 18 months is a long time to wait for that beer. I'm thirsty,
Old 05-17-2018, 08:37 PM
Dirty Steve's Avatar
That is gorgeous!! Here's a couple brews on me.
Old 05-17-2018, 08:51 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Originally Posted by smalljob View Post
All cleaned down to bare metal, all nuts and bolts cleaned in the blast cabinet and I used electrolysis to clean the fragile mulch guide. Packed all the spindles, new blades, idler, and gauge wheels.
Now I need to find time to get it mounted and test it out.
Looks great!! Bet she cuts as well as she looks too!
Great work as always!!
Jay
Proud owner of the following:
Old 05-17-2018, 09:07 PM
smalljob's Avatar
smalljob smalljob is offline
Thanks everyone. Hope to try it out in the next couple of days. This deck was not on this tractor for some time. The PO said he never used it. Should be interesting getting it setup. Looking forward to it
I was really pleasantly surprised at how robust it is and I like how it was all put together. I have never worked on a CUB deck before but I found it pretty intuitive. Very happy with the experience.
Bill
Old 05-17-2018, 10:37 PM
jaynjeep's Avatar
Bill
Yes those early decks were very beefy.. also very interesting design but pleasant to work on!
Jay
Old 05-17-2018, 11:31 PM
Great job, congrats on a job well done.
Old 05-19-2018, 12:56 PM
smalljob's Avatar
Well I got it mounted and as you can see from the grass on the deck that it works. It was a fun exercise getting the drive belt on.
I need some guidance on adjustment. It is out of level left to right by about 1/2 inch and the same front to back. I have the two eyebolt links on the front as high as they will go. That is annoying but the left to right bothers me more. I measure the two arms when lowered down a couple notches for reference as shown in the picture. The difference between left and right arms to the bottom of the frame is between 1/8 and 1/16 so the problem is with the frame I guess. On other decks I have worked on one side is adjustable, but these are both fixed.
The only thing I can think off doing is somehow shiming the pin on the one side to accommodate for this.
Looking for some advise. I will not be using this for my mower, but I'd like to get it closer. Thanks
One other question. Usually you set the gauge wheels about 1/2 above the ground. Is that the same for these or do these ride on the rear gauge wheels? Because if I let it ride on the wheels it would level out on its own.
Old 05-19-2018, 01:53 PM
I always let the deck ride on the gauge wheels.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-19-2018, 01:56 PM
smalljob's Avatar
that gives you a pretty short cut even with the gauge wheels all the way down right? How about the front eyelets?
Clearly that would eliminate my problem.
Bill
Old 05-19-2018, 10:55 PM
Can't you put a adjuster on the one side?
When I use my tractors for cutting, the gauge wheels are on the ground, more than off. I know "they" say they shouldn't be, but that's how I roll.
