Old 02-06-2017, 07:22 PM
Got a good start on the electrical system for the 2264 today. Hope to have all the stuff behind the engine finished tomorrow so I can plop the engine in place. Salvaged a lot of the factory wiring and repurposed it. Weather was awesome, if I was smart I would have been out ridding the bike instead of playing with a tractor. Oh well I want to get it finished.
Old 02-06-2017, 07:38 PM
If you were smart you would have moved further south, hehehe just kidding....
Up to 530 and counting...
Old 02-06-2017, 10:50 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Sounds like you are moving right along!! Hoping for some pix before too long!
1- 1200 in pieces
1- 1864 in pieces
Old 02-07-2017, 07:10 AM
Lew it was 68 yesterday and supposed to be about the same today.
Old 02-07-2017, 07:43 AM
Leadslingingdaddy's Avatar
If it keeps up it will be pool time!
Old 02-07-2017, 05:43 PM
Tee shirt weather today in the shop, I'm lovin it.
Sorry I forgot to take pics today. The CH22 is in the Cub. Most of the wiring is done. New fuel in is in place. Drive shaft is in. Tomorrow I hope to finish the fuel system, new tank bushings, reinstall the shut valves, filter. Makeup the plug to connect the wiring to the engine. Battery cables etc. Then give it the smoke test.
Old 02-08-2017, 10:04 AM
farmall fred's Avatar
farmall fred farmall fred is offline
Sam, just make sure you do not let the smoke out, you know how hard it is to put it back in!!!! I am not looking forward to rewiring my project. The PO really has it messed up. He actually had a household light switch hooked up to the pto and another switch hanging under the dash that as fsr as I can tell also was hooked to the pto clutch. The CH22 should really wake up the 1864. Will this be your main mowing tractor when done?
Old 02-08-2017, 02:15 PM
Smoke test was successful, everything works as it should. Gotta go and pickup some tranny fluid now.
Old 02-08-2017, 04:42 PM
Tranny oil and filter changed, stuff that was in it was NASTY! Probably should have popped the rear cover off but I figure I'll let that go till I put the rear end braces on. The starter relay took a crap so I just went with the factory setup. It works fine without it. Next on the list is to tidy up some wiring and put some split sleeve on it and build some sort of battery hold down. Battery that came in the tractor is almost new but it's the wrong size. Then it's on to putting the fenders and hood on with the new grill. Once it's finished I'll run it for a season before getting into making it pretty.
Old 02-08-2017, 07:30 PM
Rescue11's Avatar
Looks to be coming along nicely!
1- 1200 in pieces
1- 1864 in pieces
