#151
Looks great! Now UP!
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
#152
Looks great Oak. I hope you don't have anymore obstacles to hurdle and are able to get your shop finished and get back to what you truly love, working on tractors.
#153
72 yards + a pump + a crew to place and finish = cha ching!
Looks great. |
#154
Todd try to keep the concrete wet for a couple weeks or spray a sealer on it.
#155
I thought you had given up and joined a boat building forum! I guess the rain slacked up finally!
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't! 72 scout IH 404 tractor |
#156
Looks okie dokie, what Sam said about keeping it wet.
Up to 534 and counting... I give up updating my profile! |
#157
They wet the shop side on Wednesday and covered it with plastic but now I'm concerned that we will drop to 22 degrees on Sunday night. What are your guys thoughts on that?
#158
If it going to be that cold for one night it will be fine, if not get bales of straw/hay and spread it on the plastic, then cover it so it does not blow away.
Do not wet the straw.
#159
The ground is probably warm enough that you’ll be all right. Get ahold of your concrete guys and see if they have any insulated blankets.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
#160
Todd it should be OK as long as the concrete was not poured like soup and if it was a true 4000 PSI mix. It should be up to around 2000 PSI after the first 3 days. Considering what you have put into this project so far a roll of plastic and some hay would be cheap insurance.
