#161
.....Of course you are!! .....Remote Controlled Cubs!!!![]() Cub Cadet 123
#162
replacement carb on order. I have a pile (three actually) of spare carbs but they are all for pre-QL tractors--wrong choke arm. Wondering? Can you swap this from one carb to the other? In other words, convert a 108 carb to work on the 1000. Can this be done?
I looked at the after market carbs that were on ebay a few weeks ago and that were the subject of a couple threads in the kohler engine forum, but they are no longer available. bought a used carb instead. I'm seriously considering pulling the engine and rebuilding it now.
Answered my own question. Yes you can swap choke shafts from a QL carb to a non-QL carb. Just moved the shaft from my 1000's carb to a carb off a 108. works fine. Won't get a chance to install it until Sunday, but looks like this might work.
Sounds good, glad the swap worked
Cheaper also
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#165
The shaft swaps work fine. Ive done it to just about every quietline that I put a kohler/carter carb on that had a walbro. Iirc I even swapped between the two. Can't remember
#166
Old codger here, with a newly acquired 149. It's a good looking old tractor. Runs great, but with some maintenance / repair issues.
So, I just found this thread, and read it all the way through. Great information, that will be a continual reference, for my own work. I greatly appreciate the step-by-step progress report with pictures. I am an ex-mechanic/welder/fab/ cobbler. But new to the CC world of rejuvenate. I had one of the O's (nearly worn out) many years ago, but did not try to restore it. Thanks, Steve |
#168
I put another carb on the 1000 and while it ran better, it's clear that the governor isn't working. It overspeeds and does not respond to the throttle as expected (won't return to idle) I'm still getting fire out the exhaust, so either it needs a valve job or the exhaust valve is sticking. The engine is coming out of the tractor and will be overhauled. Stay tuned for what I find as I disassemble this engine.
