Old 09-10-2015, 05:51 PM
bschmittling bschmittling is offline
Originally Posted by austin8214 View Post
It shouldn't be a problem. Just make sure your S/G has top notch bearings in it.
My S/G is only two years old so it should be good to go.
Old 09-10-2015, 06:05 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I like to recommend putting the ignition on a separate toggle switch. that way you can get the engine spinning then hit the ignition switch, its allot easier on the starter
Old 09-18-2015, 04:44 AM
Default Summary
This thread has run on much longer than I ever expected. Thank you to all that contributed, especially dvogtvpe. Here is what we have so far. Correct me if I am wrong and I will edit.
1. For safety reasons, govern the engine to 3,800 rpm. Maximum torque will be made between 3,000 and 3,400, so additional rpm are an unnecessary risk with a stock flywheel.
2. For a stock 12 hp. engine, it is best to run with a 16 to 17 tooth second gear. This can be accomplished with a 20% under drive. This is the biggest thing to make you competitive starting out. Running in a stock first gear is too low and second gear is too high if you have the standard 13/19 tooth gears.
3. For a 12 hp. engine, run a #26 carb. You get more torque.
4. For more hp. for a 12 hp. engine, bolt on an LP head. It is the easiest way to get an extra 2 hp. without rebuilding the engine. If you can't find an LP head, use a second generation head and have it milled 0.05.
Next year the engine will be rebuilt with a Kerber #3 cam, undercut valves, and a balanced steel crank.
Old 09-19-2015, 07:38 PM
dvogtvpe's Avatar
then you probably want to budget in a good carb if you're going with the rest
Old 09-19-2015, 10:01 PM
What do you mean by a good carb? I have a new #26.
Old 09-19-2015, 10:11 PM
New pull results. I pulled in three classes.
Garden modified 10 to 14 hp., 23" tires, Finished Second
Heavy modified uncut, 16 hp., 26" tires, Finished Second
and Light modified uncut, 12 hp., 26" tires, Finished First.
Seems I still don't have enough power to get past the 14 hp. tractors. Doing good to finish second in the 16 hp. class though.
Maybe next year.
Old 09-20-2015, 02:51 PM
CumminSHO's Avatar
CumminSHO CumminSHO is offline
Just for those that are green with all Gens of Cub Cadet. 2nd Gen would be your 12hp Kohler' s or 14hp Kohler? I have been following this thread very close and I have learned a lot is good information. Thank you
1965 IH Cub cadet 102
Brinly 10" plow
42" deck
Front mount snow blower
Front Mount Push Blade
Red Spring Aluminium clutch
Old 09-20-2015, 05:05 PM
dvogtvpe's Avatar
after you put a cam in it with good valve work you will find a new carb won't preform like a "good carb"
Old 09-20-2015, 05:07 PM
dvogtvpe's Avatar
2nd gen is what people call the 10 hp head with a dump area between the valves and cylinder, the so called LP head was really the first 10 hp head
Old 09-20-2015, 07:13 PM
Second generation still has the heart shaped area around the valves, but has the depression below the valves like the later heads. They are much cheaper than the LP head and will give you higher compression than later heads, but not as much as a LP head, which has no depression below the valves.
