#161
Every one I have ever had ran slick as glass! Even the worn out junk!
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
#162
Agree. I hope this isn't against the rules posting a green machine here. If so the mod's can delete this post.
This was a 1963 JD 110 that I restored a few years ago. Same thing as this original. Had to rebuilt the engine and in this case the transaxle need some repair, but end result a really nice purring K161. This had all the original fiberglass fenders and secondary belt cover all intact. Got a love this old vintage stuff !!! Nothing better..... https://youtu.be/IeqnleaJcwU |
#163
I never knew the early 110's had fiberglass rear fenders!
#164
Hey, that 110 looks great. NICE JOB...
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#165
Thank You.
#166
Curious as to how you removed the top collar on the steering column in order to get the column out of the pedestal.
I sure don't want to damage it on my 100 that I am working on. You sure have done a magnificent job on that 'O'!! |
#167
Do you mean that metal ring around the top of the tube? Normally you don't need to remove it.
You should be able to manipulate it through the grommet without removing it. Those grommets are available if you do happen to damage it. |
#168
Kinda what I figured.
The parts lookup shows what looks like it being a separate part from the tube. My grommet is very brittle, I have extras. So I guess if it breaks during removal it's no big deal. Thanks for the reply! |
#169
Yes it is separate. Not sure if you plan to rebuild your steering column, most do while it is out.
You can purchase new bearings and cups for the lower end and the little nub ( can't recall the name) that rides in the worm gear. On the top end some guys have put a bearing inside the tube to stabilize the shaft. So in that case you would need to remove that collar. On my O I did pull it off and I had a plastic collar/ spacer lying around that had the correct ID and OD so I tapped that in at the top of the tube then replaced the collar. |
