Old 09-18-2010, 11:36 PM
Thanks guys!
Looks like everyone had a good cub weekend!
Old 09-19-2010, 01:05 AM
JayBrd's Avatar
JayBrd JayBrd is offline
Lawn swept the yard today. Hooked up my hitch to the Brinly adapter, so I can use my attachments and not have to remove it.
I miss the duals..................:biggrin2.gif:
Looks like you had a good time. Leaf season is coming way too fast up here...
Jay N.
Eau Claire, WI
RED 82 Series...
Old 09-19-2010, 06:02 AM
nikster's Avatar
nikster nikster is offline
Hey Nik, would love to see some pics of your electro process and how the nose turns out, please!TLC
Well here's the ammo i'm using;
Arm & Hammer soap,
Finish remover, (lethal & some bad stuff) about $ 7.69.
2-3/16 S.S. plate,
gloves,
cheapie brush's,
Saftey glass's,
Self etching primer,
Battery charger,
pint mason jar for that lethal stuff to brush on,
There is no way i'm gonna get in there to even try to scrape & sand the backside of the nose on my # 109.
Don't want to get into sandblasting, so i'll try this?
That Tal Strip I bought at a local auto parts store is LETHAL stuff & potent. I was warned by the counter guy about using it. He told me wear glass's, rubber gloves & a long sleve shirt. Which i'm doing.
1 tbl. of soap to 1 gal of water,
3/16 S.S. plate bolted together to make it easier to attach my positive lead from the battery charger,
Rubbermaid rubber bin which i'm using to use as my cooker,
Slop the entire nose with that stripper & let it set up till I see it's doing it's job,
drop itin the tub & add water to cover,
attach the negative lead to the nose & the S.S. plate to the positive lead,
Plug in the charger & hope it does'nt blow up?
I brushed some of that brew on part of the nose & wow, it like removed the finish NOW.
Gonna take some pic's after the fact & see how it works? My 1st. attempt.
I'm setting up my camera to video mode & try the You Tube thing?
The movie may take a bit cause i'n not to computer literate. We'll see?
Nik,
Old 09-19-2010, 11:11 AM
Thanks Jay! The duals will be going back on. I'm enjoying the look the 100 has for now.
Old 09-19-2010, 11:51 AM
nikster (and everyone, for that matter)-
DO NOT USE STAINLESS STEEL FOR ELECTROLYSIS RUST REMOVAL!
When used as an electrode, the SS will create dangerous, very poisonous and carcinogenic chromium compounds that you cannot legally or safely dispose of. You don't want to contaminate your ground water and get in trouble with the EPA. Use ordinary steel only.
Old 09-19-2010, 07:57 PM
aagitch's Avatar
aagitch aagitch is offline
Picked up a brinly 3pt plow for next to nothing for my super diesel. It came with this jc penny tractor that is a hydro with shaft drive and shaft driven deck. Think I'll just sell that.
Old 09-19-2010, 08:37 PM
Nice plow, Adrian!
Old 09-19-2010, 09:26 PM
Sminkey
Guest
Posts: n/a
Default Primer
Primed the auger for the cc36 and got a seized set screw out of the pto.
Old 09-19-2010, 10:38 PM
aagitch
Nice plow
It's going to look good behind the diesel.
Sminkey
Looking better everyday
Old 09-20-2010, 12:05 AM
Great job, Jude!
