Old 09-07-2016, 08:07 PM
Dirty Steve's Avatar
Been busy last couple days. Our daughter started kindergarten so all the meet the teacher stuff was Tues and first day on the bus today so hugs were given and pictures were taken. She seemed to do just fine with it all. Boy was nervous about being at daycare by himself but he'll come around.
Mowed the lawn with the 2284
And then got back to wiring. The only gauge completed is the voltmeter. Battery was testing 12.7 just sitting there. I tried the switch....NOTHING? I started checking everything. Power at the starter.. check a bunch of other connections. Was nearing Def Con 4 when I had one of those I had installed a fuse block and guess who had not put a fuse in yet...... 20 Amp fuse and we had dash lights and voltmeter! Fuel pump was chugging. Even whirled the starter Voltmeter seemed accurate. Need to finish the other two gauges. PTO ground. Light circuit. And then make a decision if I should mess with the little lights in the guages. Getting closer.
Old 09-07-2016, 09:08 PM
Waiting for the smoke test. Just don't let the smoke out of the wires.
Old 09-07-2016, 09:35 PM
Roger that!
Old 09-10-2016, 01:12 PM
Sick bay is empty..... gauges in and done. Tractor completely rewired. Massive undertaking for me, my skill set, and limited time. Other than the lights it is done. However the beast would not run for more than a few seconds with the choke out. Panicked and started swapping parts from spare engine. Sam convinced me to slow down and swap the carbs. Purrs like a kitten. I was certain I had an ignition problem. After all, I rebuilt that carb ??? Then made a mess of things with a couple oil leaks. Forgot to tighten one line to the hydralic valves. Got it all cleaned up and drove it back in the shed under it's own power! Been chasing kids the rest of the morning or I may have actually put the fender pan and seat back on for the first time since January!
Old 09-10-2016, 01:29 PM
Listened to that vid you e-mailed me. That is one sweet sounding 2182. Ya Done Good Grasshopper!
Old 09-10-2016, 01:30 PM
Glad you are enjoying your super, Steve!
Old 09-10-2016, 02:24 PM
Sam, you the man. Would have gave up long-ago without your help.
Thanks Allen! This one has been ..... well... alot of work, bad words, and cash.
Old 09-10-2016, 02:30 PM
When your done you can take it back to the Cub dealer that couldn't fix it and bust on them.
Old 09-10-2016, 04:56 PM
Alright. A few pictures... Starting to assemble rear taillights and seat brackets. Hoping to get fender pan and seat on tomorrow.
Old 09-10-2016, 06:01 PM
I'm betting that will be one sweet 2182 when your finished. Glad to have been able to give you some guidance on it.
