Old 10-14-2010, 07:03 PM
Sminkey
Guest
Posts: n/a
Default Nice work Adam!!
Sweet looking grill and I'm sure the headlight panel will be just as nice
I got to working on the tiller and finally got the left extension off:biggrin2.gif:. Still can't get the right side to move, will give it another shot in a day or 2 after letting it soak in PB. Also had a grease fitting stuck in front wheel of Original that I'm getting ready to send to sandblaster. There was no shoulder of the nipple to grab onto and it was seated in there so tight I couldn't get the vise grips to back it out, so I welded a bolt to it and then cranked it out no problem!! Did some more priming and paint and the blower today too
Old 10-14-2010, 07:47 PM
IHinIN
Nice job on the Grill. Can't wait to see the headlight panel
Sminkey
Glad you got the grease fitting out. They can be a pain sometimes.
Hope you get the tiller the rest of the way apart
Old 10-14-2010, 10:23 PM
Great work on the grille, Adam!
Old 10-14-2010, 11:36 PM
johncub7172's Avatar
Adam- Nice work so far! Keep an eye out for an IH emblem for it now! Sminkey- Those Original rims must be awesome, because my rims dont have greese zerks for some reason. I always keep them greased by jacking up the tractor,removing the wheel and using wheelbearing grease.
Old 10-15-2010, 04:00 PM
Sminkey
Guest
Posts: n/a
Default I wonder?
Now I have to go look at my other O' to see if it has grease fittings on its front wheels too, thought they all did, guess not!
Old 10-15-2010, 04:42 PM
Jude, you are correct. All the Originals had grease fittings in the front wheels.
Old 10-15-2010, 06:30 PM
Sminkey
Guest
Posts: n/a
Default Thanks Allen!
Haven't been out to the shop yet to see, now I don't have too! Although I do here the cubs calling me to work on them:biggrin2.gif:
Old 10-15-2010, 06:49 PM
nickvanorman
Guest
Posts: n/a
well, pulled apart the motor sorta on the 122. had to replace a busted head gasket. got the head taken off with careful order of the bolts and washers for each hole. got the new gasket on after cleaning the carbon and crap off of the motor and the head. got it all bolted back together. glad i had checked the dip stick before i started it. the oil wasnt even touching the dip stick! haha so i drained what was left of the oil (the rest came out the hole in the head gasket all over the grill) and it was about a 1/4 of a quart. so i got some new oil in it, started it up and she purrs like a kitten yet growls like a lion with the stack on it. think i might go back to a muffler. we shall see. anyway, good day. next item on the list is a busted valve stem on the speedex and a new project tractor! :biggrin2.gif::biggrin2.gif:
Old 10-15-2010, 08:04 PM
ihnick's Avatar
ihnick ihnick is offline
Well I picked up the 3 tractors I purchased over a month ago. Pictures to come later this weekend
Nick.
Old 10-15-2010, 08:58 PM
camarokidz28's Avatar
Default Eleanor Update
Well now that i have all my honey do's out of the way .Started working on Eleanor this week . Made some good progess on her . Saterday will be power washing the underside , and sanding and painting .
Denny
Original Member # 389
Saw It
Wanted It
Had A Fit
Got It
