Old 02-08-2012, 09:43 PM
Sugarmaker's Avatar
Duke,
Right there when we need you!
I picked up the 4 units of 3/8 x 1.5 inch long stainless carriage bolts, washers ans lock nuts to mount the gear box to the mounting plate assembly. Getting late, may not touch Cub stuff tonight. Slacking!
Big day here! Kids just bought another house and 100 acres about 5 miles from us. Hummm maybe they will need a Cub or two also? Might be a good place to deer hunt too. Humm maybe they have lots of nice hard maple trees?
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 02-08-2012, 09:45 PM
dinkytoy47 dinkytoy47 is offline
that tiller looks like its barely trained. good for lots more years....
Old 02-08-2012, 09:51 PM
Great job on the tiller my friend. I know you put alot of time into it to make it look so good
By the way, I'll be calling soon, just about out of syrup. If anyone wants the best maple syrup, get hold of Mr. Sugarmaker, you won't be disappointed, he is da man
Old 02-08-2012, 09:53 PM
Sugarmaker's Avatar
Not sure I caught your point. Could be from me being south of the border
Regards,
Chris
Old 02-08-2012, 09:56 PM
Default electrolysis tank
I have seen a couple of pictures and reference to an electrolysis tank.
Not sure how they work or what they're used for. Sorry if this is in wrong forum. Would someone be able to fill me in on what they do and how, with possible drawing on the construction. Thanks in advance.
dinkytoy47@gmail.com
Old 02-08-2012, 09:57 PM
not trained same as hardly used
Old 02-08-2012, 10:08 PM
Sugarmaker's Avatar
Two things (or more)
Welcome!
1 Your in the right place to talk Cub stuff, these guys can help you a lot.
2. I have some pictures of the electrolysis tank I built, on here in the thread about the QA42 snow blower (snowthrower) restoration. Wish I was as good as these guys in linking to old posts Lots of other posts about the rust cleaning process. Try the search function.
3. This #1 tiller that I started on was very used and needed a full restoration. It is in good working order again.
Regards,
Chris
Old 02-09-2012, 10:07 PM
Sugarmaker's Avatar
Default rear drive unit comes together
Guys,
Couple shots of the rear drive as I put the pulleys on and mounted the drive to the bracket. Thanks again to AJ Gross for supplying the good used parts. some before shots too. Yea, used ss bolts here too.
To finish this I need to get the long belt underneath the tractor and get a mule drive set up with the solid pulleys.
Regards,
Chris
Old 02-09-2012, 10:15 PM
Sugarmaker's Avatar
Jeff in PA,
(you had said)
"I have a 1A tiller I use on my 125 ( and 122 ). I purchased deeper V pulleys for the mule drive from NAPA, part number 7-05212 ( you need two ) and also the long drive belt from the PTO to the angle. I have an early 125 and it was belt AX-144 ( shorter belt iirc ). I also purchased the tiller belt but forgot to get that belt number, I'll add it later. The NAPA belts work great and have a big cost savings. tiller belt 3VX530"
Do you know if this long belt will work on a 102 or a 127 or 147? I did get the 3VX530 belt. I am going to check pricing at NAPA too. Thanks for the info!
Regards,
Chris
Old 02-09-2012, 10:47 PM
Jeff in PA,
(you had said)
Regards,
Chris
Chris,
I know it's the correct belt for the 102 and it looks like for the others too. I'll sent you a PM with the link ( another cub forum ) since I don't know if there is a "gentleman's agreement" on posting.
The AX-144 is a NAPA number, it was like half price of the dealer.
Jeff
