Old 07-20-2017, 12:26 PM
Inactive Member
Got it....hang on
Old 07-20-2017, 12:44 PM
Inactive Member
NOTATIONS:
Since I have NO clue on your project nor any knowledge of how you are wiring, I can only supply basic information.
(A) This switch was designed to be used in the 682/782 tractor with chassis serial number 720,000> which can be found in Tech Library.
(B) This switch was designed to work along a "holding relay"
(C) Terminals C+D is your "start circuit"
(D) Terminal F is the power Input (12VDC+)
(E) Terminals A+B is the circuit that energizes the Holding Relay
(F) The Holding Relay is what energizes the PTO.
IF.....you like, I can e-mail high resolution images to the account listed in your profile.
Old 07-20-2017, 12:58 PM
sorner's Avatar
sorner sorner is offline
This is exactly what I was looking for. I can read it just fine from this attachment. I just needed something to match up the letters of the pins to the wiring diagram so I know how to wire it. Thank you.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
Old 07-22-2017, 08:06 AM
sorner's Avatar
This worked out well. I have it all wires up and everything works like it should. I used the relay from the 682 also and mounted it just inside the dash where I found two holes that fit it perfectly and it's out of the way. It previously was mounted to the frame. I cut apart another 2185 wiring harness to use the long lengths of wire in the same colors as the wiring diagram so it won't be hard to troubleshoot in the future.
#2 cart
