Good idea Todd on the diodes.
I'll have to wait a bit to check that out as I have the rear opened up waiting on parts. That diff lock arm needs to be moved between the washers, so I have to get that fixed before I can start it to check it out. Only waiting on the rear cover plate gasket and I'll be ready to put it back together. Got all of those seals that you sent me the part numbers for so all covered there. Found the diagram on a 3240 that shows that the diff lock arm should b installed between the washer and the snap ring so that explained why that thing is twisted to the left, they did not reinstall it properly. Oh.......and you were right about that spool valve leaking...not were the leak on the differential was coming from for sure but still it is leaking bad enough that I need to fix it. Thanks for checking up on the post and the suggestions.
Joe 1200 Puller[/U][/B] 1864 2072 with 54 Inch Haban Blade |
