You did what? All as Cad was saying was that the vent had to be open and not plugged. What'd you do, spray carb cleaner in the hole?
I took the bowl off and sprayed carb cleaner in that hole. Made sure it came out easy and clean. Could that have really helped that much?
108 upgraded to 12hp 127 with all the trimmings 73 WIP 75 WIP Blade, blower, decks Tons of left over parts |
Well..... if the vent was plugged, yes.
I normally soak these carbs in a gallon of Gunk then blow out the ports with carb cleaner. I guess I might have not done that good of a job on this one. I'll be running this cub as much as possible to work out the kinks.
Did you readjust the carb? I still think you were running lean.
Did you have the air filter on when driving it? |
I agree that some adjusting is still in order. I didn't realize that the air filter made a difference when tuning the carb. Now I always put it back on when testing. That was a good tip.
I was really more wondering because I've seen people block that vent hole with the air horn gasket...... |
