What's the serial # on it? Looks just like mine. I'd say the hood on yours is a little nicer actually. Mine is a dual hydro/ series 1 as well.
RUN IN THE RED 782 w/50c deck (red); 782 dual stick, 44c deck (y/w); 1050 w/38c deck; 1864 w/54" GT deck; 1872 project Cub Cadet Pro Z 560 L 42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper 1200, 1863, 1864 parts machines |
The serial number is 825870.
-1987 CUB CADET 2072 w/FACTORY ONAN B48G Engine, 50" Mower Deck, 3-Point Hitch -SOLD: '73 CC 86, '74 CC 129, '74 CC 169, '80 CC 782, '84 CC 782 "CUSTOM", '84 CC 882 DIESEL, '88 CC 1811, '89 CC 2072, '04 CC LT1024, '05 CC SLT1554, '09 CC GT2550 |
The Onan to M18 swap isn’t exactly plug n play. I did it in my 1912. It bolts right in perfectly, but you have to wire a relay for the ignition because you’re going from points (needing power to run) to magneto (needing ground to turn off the engine).
You would need this for any swap from onan to an engine that doesn’t have points.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower IH Cub Original with deck #2 cart GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck |
https://www.onlycubcadets.net/forum/...t=20875&page=2 You can also get there by clicking "Parts by Jeff" at the top of the page. Jeff |
I love Onan's too!
Gary's Place is pretty hard to beat on prices for Pistons, rings, rods, gaskets and seals. DSCN2204.jpg DSCN2216.jpg I think it would be easier changing the oil pan and using a new starter. I had to switch the rear bearing plate(front of engine) so I could use the original 982 pto also. The one on the left is from a 982 and the one on the right was from a Grasshopper mounted pto. DSCN2098.jpg
Nice looking 782, did the rod ventilate the block?
Surprisingly, no. The engine still runs pretty good on one cylinder. It even has a new starter. But I'll be selling the starter and the adjustable-jet carburetor when I get it pulled out of the tractor.
Aside from being able to use a CV driveshaft, is there any other advantage to using a Cyclops hydro pump with the splined shaft? I'm debating whether it would be worth swapping the pump with one from an 1862 or 1864. I might just be making this project more difficult than it needs to be.
Also, at some point down the road I would like to install power steering using the parts from an 1862/1864. Would I have to swap the pump for this too, or can I still use the original 782 pump?
Great to know, thanks!
