According to Kohler, the Carb Repair Kit for the (#62509) engine is: #24-757-03-S.
It can be had at you local CC or Kohler Dealers, or at our sponsors listed above.
I was looking at that carb in the link and the most sellers had bad reviews on carbs and other stuff in the recent months. One seller in Ky. is the only one I might take a chance on if cleaning it out does not work. Here's some pictures. ccc19.jpg ccc20.jpg ccc21.jpg ccc22.jpg ccc23.jpg ccc24.jpg |
I got a cheap gasket and screw kit off e bay. I will try that. I will check the sponsors for other parts. Thanks |
Looks like a nice solid 1864. Good luck on the kit, keep us posted on your progress.
Always better to try to rebuild the original stuff but nothing wrong with a cheap aftermarket piece if it's plug and play and works. That's always a gamble tho' You could install one of the cheap carbs while you are rebuilding and let us know what you think. |
Those cheap carbs seem to be " hit or miss," if they are going to work. I recently put 2 on small engines. One carb worked fine. Another one I bought, I had to work on some, before it functioned. Still , cheap enough.
I guess you get what you pay for and sometimes you get lucky. I would probably buy a carb and cross my fingers.
I've used several of the ebay carbs linked to above. They've all worked right out of the box. Though a couple of them seemed to run rich they did still work better than the original.
I have tried rebuilding several also, success has been worse than the new carbs. I'm pretty sure my problem with the kits is the tiny o-rings on the emulsion tube. I also had a couple the emulsion tube break when removing them.
JD x475 |
