Old 11-30-2013, 01:55 PM
FlyingB FlyingB is offline
Nice, looks like fun.
Phil
A nice 1710 and QA42A snowblower.....and more to come .
Old 12-01-2013, 02:56 PM
looks good
Old 12-17-2013, 09:16 AM
Peruvian Peruvian is offline
I was thinking of this same thing when I built the tool bar for my hilling discs. Can you provide some more close up photos and one when the tool bar is lifted (I'd like to see the clearance).
Thanks!
Old 12-17-2013, 03:25 PM
782CC 782CC is offline
I will have to get it out and hook it up for your pics. Not a big deal just need some time. I did leave a lot of room for adjustments. It can go much higher. The rake will go either way in the mount. short tines down and longest setting on the hitch lift will dig about 1.5 inches down. It also has the longer hitch that Jeff in PA made for me. which helped. I was using the shorter lift pin. Using the longer I can get more range. Oh, I can also flip the brinley mount if I needed a low mount. Will try to get some pics this weekend and measure range of lift which is what you really need.
Old 12-28-2013, 11:10 PM
How if this. I have more down than it shows. Showed about 3/4 inch on the cylinder. Oh, ignore the angles at the top. I was working on a rack for the back today.
Old 12-28-2013, 11:13 PM
One more. Let me know if you need a different view.
Old 12-29-2013, 01:07 AM
Very nice! Hope to see some action shots soon.
Old 01-09-2014, 11:57 AM
Thanks for the pics.
I've thought about using unistrut square tube or similar with holes already punched and then 12" spike nails for the rake. I doubt it would hold up to frozen ground but likely would be nice for light grading in the garden.
Old 01-09-2014, 01:00 PM
Spikes would be more durable than my 1/2 rod. I wanted to go that route but could not find any.
Unistrut is pretty light weight and I think would twist. So may not move much material. Which means it will bend up darn quick behind your machine. I had also thought about using the over-sized garden rake. But had material and a drill press so knocked it out. I am overall pleased with the results on mine. Might have gone further apart on the tines. But width needs is all about the dirt/grass or whatever I am moving at the time. If we get icy hard snow in my neighborhood, it may get to play in that too.
Old 01-09-2014, 07:15 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
LOVE IT!
nice work
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
