The solenoid plunger has to stroke the full distance for the disc to make the motor contacts to spin the armature. If it's not a full stroke, the armature won't spin and the the pinion gear won't hit the flywheel. Just make maybe a clicking noise. If your starter armature is spinning, the starter pinion has to contact the ring gear unless the starter drive is bad. So, I'm somewhat confused by you problem description. https://autosystempro.com/starter-co...it-components/ |
Starter problem has been resolved. Neighbor has given me a used starter, installed it and mower now starts as it should. Thanks for your replies and suggestions.
