This is what I use to repair Cyclops plastic.
I love my 1862 but as stated the plastic is a problem if a PO didn't care about bumping into things. I just put a NOS grill shell and hood on mine and now making a bumper for it. But then I can see a tree if it is in my way so hopefully I will not need it. You will LOVE the power steering! Mine has the 50C deck on it and I can put the edge right up against the tree truck and circle it all the way around without backing up.
Cub Cadet 1811 undergoing restoration Cub Cadet 1862 waiting for paint Cub Cadet 1050 finally got all the parts bought so next in line behind the 1811 for restoration Allis Chalmers 416 Massey Ferguson MF-8 Brinly 10"plow Soil Mover garden tractor dirt scraper Taking donations for a new bigger garage to hold them all |
I love my 1862. I've had it for about 13 years and got it from the original owner. He cared for his equipment, but mine had a short, uncared for, layover with my landscape company. When I got it back, I had to clean up some rust from sitting under a tarp for a year or so, but other than that, no worse for the wear. The mag 18 plows thru wet, long grass, but it's main use is running the 450 blower (I have an early 1862). The power steering is fantastic (comparing to my 982) especially with the heavy blower on the front. Other than that, it's a Cub Cadet with an aluminum rear. My plastic is in pristine shape (knock on wood) and just takes a little thought to make sure you're not running it into anything. I've heard the comments about the electrical system, but again, knock on wood, I've not had any issues with mine.
Kubota B7100 HST 4x4 w/FEL, 4' Bush Hog, Woods RM400 Finish Mower Original Member #54 |
Guys using the hondas as repower were having overheating problems due to the small open area for the driveshaft adapters...No airflow to cool them down...
Now...The ultimate CC would be the 1872/2072 with a Command/Vanguard engine...Say 20hp...All metal with all the goodies...JMO... |
+1. The xx72 Supers are my favorite as well. I love my 1572.
I had an 1863. This tractor as well as 1862 and 1864 are great ones provided the previous owner did not abuse them. In researching it, I read they had issues with the plastic hoods, electrical issues, and paint peeling. When I had mine, I can verify I had electrical issues and paint peeling badly. I would be waxing the tractor, and paint would come off. I had other issues with it so I traded it in. My uncle had an 1862, and his looked horrible--he did not take care of it. I have also heard the Magnum engine has governor issues. 1863 and 1864 had Kohler Command engines which some argue are better than the Kohler Magnum engine found in 1862.
I think the Mag's have more 'grunt" than the Commands but as far as sippin fuel and ease of getting replacement parts and cost these days....Command...
Biggest problem that I've had with my 1862 is the electric pto. It has to be replaced every 2-3 years. I've owned mine since new. Other then that it's pretty bullet proof.
That seems a bit odd....Are you overtightening the belts or are the aligned correctly?
Should last longer than that.... |
What is going wrong with the PTO? They should last longer than 2-3 years.
