AC
If you can't get it going I'll fix it up for you if you can haul it to my place. Pretty sure the starter solenoid is under the seat next to the battery.
That's where the solenoid is on my 2072, should be the same. In order to jump the solenoid you take a small wire and touch each copper end from the small "s" post to the large post, or use a screwdriver, correct? |
Edit: Image is of a generic solenoid I grabbed from online, actual solenoid may differ slightly but the procedure is the same.
-Ryan
On both my IH 982s the soliniod is under the seat beside the battery you will see two threaded posts sticking out with two hot wires take a screwdriver and touch both posts at the same time don't worry about sparks the engine should start turning over hopefully it will crank if it does replace I have a bad soliniod on one of mine and that's how give been cranking it for two weeks now .
-Ryan
Thanks Sam, I really appreciate the offer! It will be too hard for Jenn and I to get the 982 in the trailer with it not running.
I also tried to look at the solenoid, and can't see it at all.
Hope you can get your 982 all fixed up soon. I love when you post pictures of it, it's a beautiful machine.
'74 IHCC 108 - 38A, supersteer axle '75 IHCC 1000 - 44A, Sears wheel weights '87 CC 1872 and 1811 - Haban, 44C '96 CC 1863 - 54GT '79 JD 400 - 60" deck "Projects" '67 123, '65 102, '71 126 |
