Old 06-13-2020, 05:43 PM
Good deal!!
Do it right, do it once!!
Old 06-13-2020, 07:45 PM
twoton twoton is offline
Good deal!!
What he said!
Curious about your 3 pin driver?
Old 06-13-2020, 09:17 PM
Originally Posted by CSXengr View Post
Update on the 1200 clutch problems!
Inspected the clutch, plates, bearing and teaser spring. Replaced the clutch and teaser spring along with rag joint. Will have plates surfaced.
Inspected motor mounts as suggested and sure enough they are shot! So now I have pulled the motor and inspected the bushing where the drive shaft goes into, worn out! Will be doing the cradle mod and replacing solid motor mounts from Jeff. I had a set on hand. Along with the bushing.
Hopefully this will solve my problems. But if you see anything I have missed please tell me while I have this tractor torn down.
But thanks for everyone's suggestions. You all were a big help.
I can resurface the clutch plates on my Monarch lathe. I indicate each side to make sure they are parallel so they work correctly.
Jeff
