Old 06-11-2015, 10:23 AM
You may want to put one of these battery disconnect switches on until you can get the tractor fixed. At least it will isolate the battery when not in use. Just turn it off when your done mowing.
http://www.amazon.com/Volt-Battery-D...G1YZ2V3KD3JSE2
Old 06-11-2015, 12:09 PM
CubDieselFan's Avatar
All of the dealers in my area quit selling and servicing Cubs all together. MTD did not want to pay their labor rates to repair the not so good new stuff.
Old 06-11-2015, 02:53 PM
Travis959 Travis959 is offline
Battery seems to charge just fine during mowing. I am generally able to start the mower for a day or two after I've mowed previously. Any longer and it becomes a luck of the draw kinda thing.
Thanks, I've never seen one of these before. Should definitely make the problem much more tolerable for the meantime.
Old 06-11-2015, 10:57 PM
A wing nut on the negative cable would be my fix. It is sad to say what has become. Everyone has sold out.
Old 06-12-2015, 09:24 AM
I actually have a wing nut on the positive cable of all my tractors and unhook it whenever I park them, none of them drain the battery but its cheap insurance that the tractor will start regardless of how long it sit and keeps the points from getting burnt if my son is playing on them and leaves a key on.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-12-2015, 10:01 AM
What am I missing here?
It's a NEW machine it should perform properly!
It has a warranty,---- wait long enough and it will expire.
Did you or did you not call/speak to them? Did they give you a replacement battery? or did you have a good one on hand, that you tried?
In my neck of the woods, TSC is awfully nice about making things right in the event of a problem.
Best of luck!!
Old 06-12-2015, 11:45 AM
Terry C's Avatar
Terry C Terry C is offline
X2. I call it kid proofing
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 06-21-2015, 12:46 AM
Moark Willy Moark Willy is offline
My local Cub Cadet dealer only fixes what he sells. People that buy from the big box stores will have to find and travel to find a servicer that will work on them. This can be a major PITA.
Complain directly to Cub. The dealers have an obligation to fix all warranty work, just like car dealers. If they refuse, report them.
Old 07-01-2015, 07:39 AM
zhitch41 zhitch41 is offline
My new xt1 is doing the same thing. I also purchased this mower from TSC. What did you end up doing? what was the problem? Thanks
Old 07-01-2015, 09:35 AM
SGragg SGragg is offline
Around here, if you buy a Cub Cadet from a big box store or TSC, you take it back to them for warranty work. My local Home Depot and TSC will then ship your mower off to who-knows-where for repair, then ship it back. This process can take up to two weeks.
This is why I purchased my Cadet XT2 from a local Cub Cadet dealer. Interestingly, for the XT1, the Home Depot website shows, "No hour/3-year limited residential (including the power train) and 5-year chassis/front axle warranties" while the TSC website simply states: "Limited warranty."
Regardless, it's a new product, it's not performing as designed (aka, manf. defect), therefore, return it to TSC.
