Monarch CK 12 lathe |
Getting the old ones off was quite easy.....Putting the new ones on, especially the second beads...not so much!
Nice hammer....Been around the block a few times?... |
Bcdsfcret
Get your self the small tire changer from Harbor Freight tools. I have one and it makes changing the small tires easy.
I made mine to mount into the receiver hitch of my truck. Brian |
going to look into that small changer......thanks
But I believe my biggest difficulty was doing this with inner tubes. Made it difficult for the bead to sit in the recess prioperly. |
The tires look good! Now try mounting a set on freshly painted rims without scratching them.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart |
OK.. first time I have seen a lathe used as a tire machine. Not sure the bed on mine is deep enough. I've done some pretty small tires on my coats 10/10 however.
It helps if you warm them up in the oven first. Mike
I was complaining to an elderly gentleman (76),lawn tractor repairman he is, about changing those little burgers on the front . He showed me his little trick and said work smarter not harder. The trick ....WD40 . Makes changing tires so much easier you'll want to throw nails in your driveway !
149..... qa-42 snow thrower..#1 tiller w/extentions, 109 w/deck, 129 w/blade 1450 w/deck Case 444 gt.....H270 toro wheelhorse....Massey 135 diesel.....52 GMC |
I used both a spray made especially for changing tires and a jar of Tire Changing Goo.....Both helped, but not enough!
