Old 01-30-2021, 01:01 PM
ironman's Avatar
ironman ironman is offline
If you had the head off, and aligned the flywheel timing mark to the "T" mark you should see the piston at exactly top dead center and both the intake and exhaust valves should be fully closed.
Rocking the flywheel slightly back and forth in both directions you should see some movement of the valves.
However, I dont know what it would look like if the gears were one tooth off. It might not be enough to gauge by looking at the valves.
In order to actually see the marks you have to remove the aluminum bearing plate.
Question: Do you have coil ignition or magneto ignition?
Old 01-30-2021, 03:56 PM
raylee raylee is offline
want to thank everyone for their help I put another new condenser on it and runs as it should once again thanks from everyone on the best cub forum on the internet
