For now I'm going with JD. This thing runs too good to use for parts, so I'll just set it aside for use on some future project.
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake |
Make up your mind. It's a Deere then. |
I guess you didn't understand my description. I tried to explain the set up the best I could. I didn't do a good job of it I guess. I did say the 4" pulley was behind the clutch. The pulley set up is in the picture. Sorry for the confusion.
It was my bad. I didn't see the pulley behind the clutch.
No problem J-Mech , Bottoms up
