Old 12-20-2019, 02:51 PM
taylorjm taylorjm is offline
The big thing to look at is the lumens the bulbs put out, since that is the measure of actual light the bulbs produce. Right now my shop has the 2 bulb 4' fluorescent bulbs at almost 3000 lm per bulb, so 6000 lumens per fixture. I've seen the led bulbs that can go to maybe 5000 lumans per fixture, but at 3x the cost, I can't justify it. Especially with 10 fixtures in the shop.
Old 12-22-2019, 04:08 PM
john hall's Avatar
A few years ago we had the entire machine shop I work at converted to LED lighting. The power company sends out a guy to assess our lighting needs and then makes a proposal. Seems there was some sort of government assistance to encourage businesses to switch to LED lighting. His proposal showed that within a short time (3-4 years I think), we would save enough money on the power bill to pay for the conversion. After that it's all money in the bank. Power company sent in a 2 man contractor crew--they switched over every light in the plant and barely disturbed us at all. One guy could change a light over in 10-15 minutes.
I broke down and switched the farm shop to LED last year. The fixtures ranged from 15-50 years old. One guy swapped them over in a little over a day, essentially rewiring the entire fixture. Unbelievable the difference it made.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 12-22-2019, 09:18 PM
According to the info, the frosted cover ones I got are 6500 lumens per bulb.
I had "too much light" and moved two further apart after converting them.
Here's what i purchased
https://www.ebay.com/itm/25X4FT-LED-...c_yU_H_1aYAFyw
10 bulbs $46
25 bulbs $104
Old 01-13-2020, 08:52 AM
V30crewcab V30crewcab is offline
Just swapped out ten of my 8ft lights to led in my shop. its night and day difference. need to order another box and finish it . I can actually see in the shop now!
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 01-17-2020, 03:14 PM
10 bulbs $46
25 bulbs $104
Sorry for replying to an old thread, but your link doesn't say they are 6500 lumens, it says they are at 6500k, which is the color rendering. 3000k is a warm white and the higher you go up to 6500k is a daylight. I've never seen a 4' led bulb that could come anywhere close to the lumens of a fluorescent bulb. Usually half of the light output.
Old 01-17-2020, 05:17 PM
cheesedawg82's Avatar
cheesedawg82 cheesedawg82 is offline
I just replaced a couple of 8 footers arond the perimeter of the building at work with 42w l8t8b/850/42f/r17d part no 74539 made by a company called Topaz. $28 per bulb from the electric supply store.
It was simple, cut out the ballast, tie the wires from one side to the white, tie the wires from the other side to the black, put the cover on, add a sticker, and put the new bulbs in. It's like someone turned on the sun out there now, and I put one bulb in each two bulb fixture.
Grumpy old 149/1A tiller, Trusty Rusty 106, & a Massey Ferguson 10 to work the garden, Tiny Snapper to mow the lawn. Slowly accumulating attachments and quickly driving the neighbors crazy on a half acre homestead.
Old 01-18-2020, 09:25 AM
ejl6658 ejl6658 is offline
I replaced the screw in bulbs in my basement and part of my shop with these
https://www.amazon.com/Deformable-Ba...a-801816533886
Sam I see the style you purchased come in 60W and 100W. Did you use the 60W and are they pretty bright?
Old 01-18-2020, 05:08 PM
The 60w puts out 6000 lm. To give you an example, a typical 60w equivalent led light bulb puts out about 850 lm. A 100w led equivalent would be about 1200lm. So 6000lm would be quite a bit depending on the area you are trying to light up. The 100w would put out 10,000lm which is pretty crazy. That's close to the equivalent of some lights in a parking lot or those big sodium/metal halide type outdoor lamps.
