These are the major reasons I decided to find the correct parts for it rather than modify the WH designed ones, and end up with more issues. You can PM me if you want more details. Jeff (teet)
CCC 1211 71 127 102 122 1962 Original |
Teet,
I am not trying to argue this. Just trying to get to the bottom of it. Sorry if it sounded that way. But I just don't understand. You say that the 1650 crank fit witch I fully believe it did. And Supposedly if there is a difference between the 12-14-16, it is only the counter weights. Then why wouldn't the 12hp crank fit ? According to parts tree the 1250,1450,and 1650 all have the same crank, per part numbers.
Sold everything but one. 1211-snow pusher, cab ,54 inch plow, loaded tires (all 4) Gilson wheel weights, X-trac fronts- soon to have power steering and dual hydraulics |
Jeff (teet)
Teet,
That would be great if you could compare the two. And if you still have that magnum 12 crank, could you compare it to the k series. I looked up the crank part number for a 1211. The magnum has a different number, but only the last 2 numbers are different. Maybe a change in the PTO end, for the newer style clutch ? Thanks JOE
I ran down to the shop (in a hail storm..ugh) and took a look at the cranks...my wife has the camera on a business trip, so I couldn't snap a pic, but I compared all the measurements with a digital caliper, and they all are the same. The crankpin on all 3 K301-K341 and M12 are the same, as are the bearing surfaces. The only noticeable difference was that the counterweights on the K341 are larger than the other 2. I could see no difference in the M12 to K301 crank...length or otherwise. Check this out, might be useful for you.. http://www.smallenginesuppliers.com/...-reference.pdf Wish I could help ya more! Jeff (teet)
OK, so I think it is like this, Parts tree must have the wrong number for the 1250. That would explain why their number is the same for 1250,1450,and 1650, but different then the 1211.
K341 From a 1650 in a 147
There are some challenges, one being the muffler, since the pipe is 1 1/4" where-as all the rest of the K series are smaller. There is no room for a QL muffler and it's doubtful the 169 muffler will work. (Too pricey anyway) There are many solutions, I opted to go stack with an insert muffler.
I utilized all the QL electricals incuding the electric PTO. I also retofitted balance gears with new hardware but still at a slow idle that big K341 rocks in the frame to where flexing can be seen, Point being, the K341 may be hard on narrow frame. Still was a fun project to put together, and the torque is outstanding. |
This is the reason for the wideframes. The narrowframes will twist with the engine's torque. They also are notorious for cracks.
I have a john deere engine in a 1250 that I do remember had issues with mounting the PTO and therefore no functional PTO, and when I moved the motor to a 122 it had issues with the generator arm too. You may want to compare the bolt patterns on that side of the motor..
Quietlines and narrow frames, mostly projects but I mow with a 1200 and have a 122 set up for pulls. Wandering the country bringing towers to wind farms everywhere, and bringing yellow stuff home to Texas. Also into flatfender jeeps. |
