Restoring old (anything) costs more than the original purchase price. As has been pointed out, it's a bargain in the long term.
The Armstrong lift is works well, and isn't a bother to use. If the rest of the tractor works well, the fact that the electric lift is doa is a minor issue, really.
Remove the motor from the lift and test it by itself.
I had the same issue with my 149 and took the motor to a repair guy in Cedar Rapids and had it back in a few days for around $50 IIRC. These things stick right out there in all the elements if left outside and we all know water and electrical stuff don't play well together. |
I don’t really want a aftermarket one I’d like to keep it original as possible. I haven’t had time to really work on it much besides checking power at the plug. I know the headlights aren’t hooked up which I intend to do the light switch still moves so that’s a plus and there is a wire missing from the regulator I believe it’s there in the mess of headlight wires and it always is discharging. I got the lift to work momentarily when I first got it home by jiggling the wires that go into the cylinder but I went out the next day to mess with it more and it wouldn’t move. I’d be ok with finding someone who could rebuild it but idk were to start looking.
I'd probably start looking in the yellow pages for an electric motor repair shop in your area if you have put power directly to the motor and it won't work.
I've never had a CC electric lift apart before, but generally 1960's vintage motors aren't that difficult to rebuild. A diy brush and bearing replacement might just get you another 50 years of service.
Grumpy old 149/1A tiller, Trusty Rusty 106, & a Massey Ferguson 10 to work the garden, Tiny Snapper to mow the lawn. Slowly accumulating attachments and quickly driving the neighbors crazy on a half acre homestead. |
When I first got my 127, the lift was very slow and worked intermittently. I took it apart, drained out the water, changed the grease in the worm gear/clutch area, brushed out the rust in the windings, flattened the brushes, cleaned the commutator bar, and gobbed some silicon around where wires go in. That was 5 years ago. It still works great lifting a qa36 snow thrower all winter long with no assistance. I would give cleaning it up yourself a try, what is the worst that can happen if it already doesn't work.
Just pulled the motor out and apart and she is definitely fried even smells like burnt wire.....not very happy right now
My 147 electric lift also worked intermittently. Cleaned worked better. Then the switch gave me problems. Needed it now so I bought just a switch locally,works but sometimes doesnt. I'm new to repairs for the lift so I'm just reading and trying. Bought a 149 with hydraulic lift that needs started. Busy with house repairs.
If you send your shipping info I can get an amount for shipping and send the part today!
It looks to be about $11.00 to send. Are you going to do PayPal or sells via your bank?
