should be 30ft/lbs IIRC.
And then retorque after one heat cycle, or about a 30 min run then cool down.
Thanks everybody.
My Do list now
Buy Muffler Buy Sediment bowl Buy Tires Buy Sleeve Hitch Fix leaking carb Buy another hydro fan Seem like the list is not as bad as before still need it finish by the end of February |
Will this work on the 129 ?
http://www.amazon.com/Replaces-Kohle...kohler+muffler |
Should work fine.
Was hauling a load of firewood today and the motor seized up I just checked the oil before starting it.
Man, that's a drag.
I took the head up and turned it by hand a couple times now the pistons moving again and it runs fine so far. I don't what causing it to stick.
Sometimes the exhaust valve can stick.
