Old 09-03-2011, 09:02 PM
The electric PTO will not 'clear up room in the front' for a PS pump, as it would take up essentially the same amount of room that the mechanical clutch does. It doesn't matter anyway, because you can't use an electric clutch on an engine with a starter/generator. You can run a PS pump off the small pulley on the flywheel end of the screen; not only is this how it was done from the factory, it is also how several members here have accomplished the same thing. It will also be better for your hydraulic system if the pump is not mounted near the hottest part of the engine.
You don't need 14 or even 12 hp for a hydraulic pump. 10 will be plenty, and a 10 hp K241 will fit with no modifications.
Old 09-03-2011, 09:48 PM
neo71665 neo71665 is offline
Thank you for clearing that up. I couldn't find any info on swapping the pto so I couldn't cross measurements up to see if there would be room or not. One thing I can mark off the list.
I thought I read the 12 will fit with no mods. If I'm gonna look for a engine I might as well try to find a 12 unless there are problems else where. Then again you talking to a hardhead that likes to build a drive v8 powered s10s. I will keep the 10 in mind if I can find one in good shape cheap enough but would still like to learn about all swaps.
Old 09-03-2011, 09:54 PM
Both the 10 and 12 will fit with no mods, provided they are set up for a starter/generator and came out of a Cub Cadet.
Old 09-03-2011, 10:05 PM
Right now I have the word out I'm looking for all narrow frame cub stuff. Hopefully some good stuff comes my way, like any search will have to wade all the useless and wrong stuff.
