You're in for quite a project if you don't go with a K series Kohler with a starter generator hanging on the side. I don't think you'd find anyone here who would say go for it. I don't know where you are at in PA, but this might be a good place to start with your project:
https://harrisburg.craigslist.org/fo...760988182.html Other than that you'd be better off finding a parts machine that has an engine.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower IH Cub Original with deck #2 cart GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck |
GO FOR IT!!
If that were closer, it would already be in my trunk for that price!! |
Cmon. Where’s your sense of adventure? I went to somerset to pick up a similar deal a while back from Harrisburg.
I did drive almost to Erie to pick up the tractor... hmmm. I suppose I could check craigslist after Christmas...
Your in about the same situation I am with everything. Need an engine for my little burns but can't find nothing close enough.
What do you need for the Burns? I'm close and I have a couple motors. Nothing period correct, but maybe something.
I'm looking for something small, horizontal shaft. Like a k181 or 8 hp. Also looking for a magnum twin horizontal to swap into something.
I have 2 good snowblowers with 5hp Tecumseh horizontal shaft motors if you'd want to trade stuff for one of 'em.
I'm looking for a horizontal shaft. A vertical won't work as the tractor is belt driven. I would be able to just use a gearbox but the layout of the front end is too crowded for that.
