if the rear belt driven pto was used, just turned 90 degrees so that the output was facing the rear, you could use a snowthrower driveshaft. I belive the shaft used on the mower in the picture was custom made. but as I was saying using full sized PTO driveline parts with and adapter for the cub PTO output it would save having to fabricate a shaft. hmmm, starting to think I should get the welder out and put pen to paper so to speak.
http://www.onlycubcadets.net/forum/s...ead.php?t=7866 |
I stand corrected 1 to 1.5 and 1 to 1.2. I knew there was a five in there.
where can I get one of those rear ptos? my dad doesn't believe me that they have them.
Bi-Polar Plowboy Plowboy X Press |
Here is the deck to use, it is set up for shaft drive already!!
It is off an Ariens GT-18. The shaft is facing forward. Who is adventurous!! Heck, bring me a box of donuts, and I will give you the deck!! |
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
Merk
Your Dad is one very talented craftsman. That is beyond cool. Love to see more of it when you get the chance, especially the rear PTO. Looks like you were having fun with it.
Me too
does anyone think you could use the factory rear lift? it would be like a sleeve hitch adapter mounted to the deck. use an extended pin on the lift casting and use chains to pick the deck. I know the arc of the pivot would be kinda extreme, but not much more than a 5ft with a 3pt. the next issue is making the cut height adjustable and getting the whole thing to float.
