Nice, pulled the cam?
Just remove the spring on the motor and "tweak" it a bit. What do you have to lose? I've done it.
What he said,takes nerves of steel though...
and small, nimble fingers. I got the old spring off, but can't get it back over the post--even using a dental pick. I will have to try some more. I want this engine to run, again. No smoke, oil stays clean, runs and idles well--too nice to go through a complete rebuild. I may just get a gasket set, and tear it apart so I can attend to the spring on the bench.
I think I will switch my focus to the 782. It suddenly developed a large oil leak that seems to be behind the sheet metal on the hydro side of the engine. If I pull the engine bolts, is there room to slide the engine forward and remove the sheet metal? |
Took me 5 min,I have fat fingers to match my,
Gloves!!! I had no problem getting it on,can you juggle?
Tie a thread to it in case it gets away, you can retrieve it. Snip off the thread when finished.
Richard 1979 IH Cub Cadet 782 w/CH20, dual hydraulics, power steering and Cat 0 three point |
Good idea! Thanks
